-   -   1967 Only (https://67-72chevytrucks.com/vboard/showthread.php?t=752576)
CG 12-14-2017 09:23 AM
1967 Only
So I was reading a thread about glass and saw where the wing glass on 67's might be different than the rest of our trucks. I had never heard that before. I knew something about the wings were different but I was thinking it was just the little locking handle.
How bout listing everything from a 67 that is different than the rest of our trucks.
Grumpy old man 12-14-2017 09:35 AM
Re: 1967 Only
Vent windows /handles
vent window glass / no hole in glass for handle
ash tray face thinner
ignition bezel smaller
last year for small back window
67 had flip forward bench seat
dash bezel 67 only
no side marker lights
67-68 last all metal grille
frame not dimpled for power steering box
no big block option
black wrinkled glove box door 67 only
interior door and window handles
exterior door handle 67 only
first year of body style
power steering was ram assist
:chevy:
Shinysideup 12-14-2017 10:02 AM
Re: 1967 Only
Wow, I had no idea about most of what Grumpy listed(thanks), good thread idea!
CG 12-14-2017 10:25 AM
Re: 1967 Only
Yeah he is the 67 guru for sure. And now I know why the vent glass is a one of.
Rods 12-14-2017 10:55 AM
Re: 1967 Only
Here's a few more 67 only
Also had bullseye back up lenses
Rear view mirror
Both RH & LH doors
All of the Insturment knobs
Radio knobs
Seat belts
LockDoc 12-14-2017 11:12 AM
Re: 1967 Only
Small metal fan shroud
Smaller holes on core support mounting brackets on frame
No accessory position on ignition switch
Small Octagon head ignition key
LockDoc
tutone 12-14-2017 12:56 PM
Re: 1967 Only
Mine only is drilled for a driver's sunvisor..
chewychevy67 12-14-2017 01:31 PM
Re: 1967 Only
The kick panel vent handles are mounted higher on a 67 so the vents mounts are stamped just a little higher where the rods latch. The door under the panel where you unbolt the outer handles is different. 67 gates are stamped smooth around the large rectangle indent as in 68 they kind of stamped a "edge" profile around it. The pass side firewall is stamped different (due to the additional big block offered in 68). Frame is also made thinner in engine bay in 68 and up to clear the big block manifolds. Rear view mirror arm is 1 year only. The visor clips in 67 are 1 year only. V8 engines used a 4 jet and 68 up used Quadra jet carbs.. List goes on and on. It's almost like 67 is a 1 year model but not really.
67chevemall 12-14-2017 03:30 PM
Re: 1967 Only
Great thread. Learning lots.
Slope on the front of hood?
demian5 12-14-2017 03:38 PM
Re: 1967 Only
Yeah, my 70 truck had a 67 glovebox and bezel on the dash. I still have them laying around.
tutone 12-14-2017 04:03 PM
Re: 1967 Only
No one has mentioned the parking break being a pull handle. Not sure if that is a one year thing or not. I had a 68 but honestly dont remember where it was on it.
novice 12-14-2017 04:39 PM
Re: 1967 Only
67-68 had the same slope but only those years.
Re: 1967 Only
68 had that as well.
Harleys 4 You 12-14-2017 06:02 PM
Re: 1967 Only
No armrest
Bob B. 12-14-2017 06:16 PM
Re: 1967 Only
Early '67 GMC Wide-side tailgate is different. Smaller boarder around 'GMC' stamping.
cypressbog 12-14-2017 06:29 PM
Re: 1967 Only
Power steering area of frame.
Orange67 12-14-2017 07:13 PM
Re: 1967 Only
I'm curious about the buddy buckets. They were available in 67-68, but all of the repro covers I see don't match my 67's original pattern. Anyone know if there was a difference 67-68 patterns?
dennislbrooks 12-14-2017 07:33 PM
Re: 1967 Only
My 67 custom has arm rest- door pulls- but has the 66 style.
Chevy4Life 12-14-2017 08:46 PM
Re: 1967 Only
Only the 2 headlights are lit when the switch is pulled all the way out(no "running lights".
I love that look.
special-K 12-14-2017 09:53 PM
Re: 1967 Only
Bullseye lenses were 67-70
Yes, buddy bucket fabric patterns were different. '67 looked like the door panels
67-only:
Interior mirror
Buddy buckets came with CST
GMC headlamp doors have no dimples for adjustment screws/bumper has no reliefs for turn signals
283
too much stuff 12-14-2017 09:58 PM
Re: 1967 Only
Rear view mirror
Both RH & LH doors
Radio knobs
Seat belts
Bullseye lenses are a 67-70 thing
Sloped hood was 67-68
That was a 67-68 thing
Originally Posted by Harleys 4 You (Post 8105044)
No armrest
Armrests were optional
Small letter gmc gate was 67 and 68
crazyjeenyus 12-14-2017 11:22 PM
Re: 1967 Only
1-6:
250
292 - Optional
V8:
283
327 - Optional
4-Speed:
SM420 ('68-on 4-speeds were SM465)
'68OrangeSunshine 12-15-2017 06:26 AM
Re: 1967 Only
The '67 vent windows had no holes in them for the latch pivot. Instead a metal bracket on the inside had a pivot stud. Style of vent window handle was common with '66s and before.
projectking 12-15-2017 06:49 AM
Re: 1967 Only
Originally Posted by crazyjeenyus (Post 8105322)
1-6:
250
292 - Optional
V8:
283
327 - Optional
4-Speed:
Wasn’t the 6 a 230 until ‘68?
HO455 12-15-2017 09:27 AM
Re: 1967 Only
Ash tray slider. The 67 sm420 tranny case is drilled for back up light switch.
