88-2000 Center-Link ?
I don't have my truck in front of me & I'm ordering parts.... Is the center-link/draglink on OBS 88-2000 model trucks a wearable item? They have them listed in the parts choices but they appear to be a non-wearable item.
Can someone knowledgeable confirm? |
Re: 88-2000 Center-Link ?
I can only comment on K trucks, but I'm pretty sure it's not. It's a bar with holes in it. If there's a problem the idler arm is the first culprit to look at.
Thanks! |
I just replaced my entire suspension & steering parts a few weeks ago. .. For a reason, that I can't remember, my drag link was replaced ( wear in the holes for bolts?).....The adjuster ends were kept..
Lower control arm can stay as is... just replace ball joints An IMPORTANT reminder!!! >> The drag link can be re-installed backwards by mistake ( not easy to tell), when on the bench, what end of drag link goes left-side or right-side. Even though the shop I went to has a good reputation, the installer installed the link backwards. When you turn the truck, the inside wheel turns sharper, & the outside turns wider.... A backwards drag link forces the outer wheel to "scrub sideways" ( sharper)... not allowing to make a 'U' turn... or even turn out of your driveway! Needless to say, when it was corrected, the new front end was LIKE A NEW SHOWROOM truck!! ( I spoke with a Moog tech... He laughed about the reverse drag link. He said that is a common 'trick' he gives the Moog tech school students to figure the problem. A common mistake at many shops. I got the Moog upper control arms completely built with bushings / ball joint. ( why spend labor $ & sweat .... better deal allready done. If you have part questions, call Moog Tech support.... They are great & they answer the phone. |
I trust my mechanic (I'm a DIY guy) so I know parts will be assembled correctly but I have heard of people installing the draglink backwards. I looked into the 'loaded' upper a-arms as well. Unfortunately, their warranty (the RK- series parts line) is only for 3yrs. I'll just buy the parts & swap them over to my current arms for the LL warranty. Plus, there is no differing ID of which BJ's are utilized (7200lb gvw/6-lug 2500's use a different upper BJ vs. 8600lb gvw/8-lug 2500's). |
I used a long drawn-out description for other members who may not have known some details. I also DYI a lot on my truck, but when it comes to the suspension / steering, I let the pro's do it, since I didn't want to buy a bunch more tools. I spent $550.00 on labor.... about $900.00 in all parts.
( 7200 / 6 lug ) even the sway bar bushing kit, etc. .. More than worth it.. Got it back in 3 days. |
| All times are GMT -4. The time now is 06:38 AM. |
