-   -   1987 1 ton 4X4 transfer case style (https://67-72chevytrucks.com/vboard/showthread.php?t=753896)
Fuelster 01-01-2018 07:14 PM
Did a 1987 1 ton 4X4 regular cab 8 foot box truck come with a slip yoke type NP205 transfer case or the bolt on yoke type. I have taken the bolt on yoke type out of crew cab 1 tons. I have a 87 1 ton regular cab that has the slip yoke type 205 in it. Just wondering if it is original or not. It has a one piece drive shaft. The tube weld to weld is 53 inches. Thanks
sweetk30 01-01-2018 08:10 PM
Re: 1987 1 ton 4X4 transfer case style
std cab long bed k30's had slip yoke rear . crew cabs got fixed yoke for the 2 piece shaft rear .
Fuelster 01-02-2018 08:32 AM
Thanks a lot for the info.
