-   The 1973 - 1991 Blazers, Jimmys, and Suburbans Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=37)
-   -   1984 k5 (https://67-72chevytrucks.com/vboard/showthread.php?t=753970)
Oscar the grouch 01-02-2018 08:01 PM
1984 k5
I have a 1984 k5 blazer and the power locks dont work. Im getting power to the plugs when i press the switch so I replaced the actuators and still nothing, but I did find the passenger switch not working is that keeping the locks from working 🤔
Greenlee 01-02-2018 11:04 PM
Re: 1984 k5
I’m not sure about the locks, but I had a similar issue with the power windows. My passenger window wouldn’t work at all because of a bad driver side window switch. I remember it seemed odd to me that it wouldn’t even work with the passenger side switch until I replaced the driver side switch. I guess power runs through the driver side switch to the passenger side.
Another thing you might check, is there are relays for the power locks mounted on the firewall in the area up behind the gas pedal.
wjjeeper 01-03-2018 03:38 PM
Re: 1984 k5
Check the wiring from the cab to the door....... They crack/ break from years of the doors opening and closing and it could be a matter of low amperage.
68Timber 01-03-2018 03:53 PM
Re: 1984 k5
I've seen a few threads about the switches wearing out/poor contact.
Oscar the grouch 01-03-2018 08:52 PM
Re: 1984 k5
I got the locks working the relay was just stuffed up out of the way, once I mounted it locks started working now to figure out the dome lights
