-   -   1967-1972 Frame / Body Mount Dimensions (https://67-72chevytrucks.com/vboard/showthread.php?t=756455)
graham1 02-05-2018 08:53 PM
I have seen a few other threads, but haven't found a solid answer. Apologies if I am missing it. I have the service and overhaul manuals for '68 and they have dimensions, just not the ones I need. Does anyone know these or have a currently unoccupied frame they could measure?
TIA
EDIT: Looking for the red line lengths
https://i.imgur.com/WsQ902X.jpg
OL SKOOL 02-06-2018 05:18 AM
Re: 1967-1972 Frame / Body Mount Dimensions
I have a 68 short box frame sitting in the yard bare.Do you want center of the cab mount holes? Will try to get in the morning snowed here quite a bit last night.
graham1 02-06-2018 08:36 AM
Hole centers are perfect! Very much so appreciated! I'm on the road the rest of the week, so whenever is easier for you. Thank you!
OL SKOOL 02-06-2018 11:30 AM
Little tough to be exact by myself.I would have to say 57 inches give or take a 1/16.I measured both ways.Let me know if you need any more.
graham1 02-06-2018 12:47 PM
Those are the diagonals I assume, do you know the widths?
I just saw you're from Rochelle, my Moms half the family is from Mendota, small world
OL SKOOL 02-06-2018 07:47 PM
That was the diagonal measure.I will get you straight across in the morning.Just getting dark here now and i just seen this.Are you checking for a bent frame?That's why this frame is in the yard bare. Bought a truck half torn apart.Got it home started doing some measurements and found a bent frame.Once i got it torn down and measured it was pretty obvious.A simple job turned into a project. This 68 frame is going under my 70 hopefully this spring.
graham1 02-06-2018 08:25 PM
I started building a 68 on a non 67-72 frame several years ago. Just now getting back into the swing of things. I can set the cab square as I can but these numbers would help, I obviously didn't save any measurements from the original frame years ago, live and learn
OL SKOOL 02-07-2018 02:14 PM
The front cab mounts are 41 and 1/2 rear is 37 and 1/2 that is from left frame rail to right frame rail straight across.That should get you close.Good luck on your project.I might start a build thread on mine if i get my arse in gear this year.
graham1 02-11-2018 09:59 AM
Thanks! That was a big help.
And yes, start a build thread, would love to see it
