-   -   Frame questions (https://67-72chevytrucks.com/vboard/showthread.php?t=757863)
phattness 02-24-2018 08:19 PM
Frame questions
i found a rolling chassis and the guy wants $1500 for it! it has to be 71-72 as it looks to have disk brakes. it is a swb chassis with no title.
the questions are: is this a bit much on price?
where do you find more chassis to compare prices?
anyone have a lead on a k10 frame?
I have a 67 swb small window that someone put on a 73-80s 4x4 frame and cut the fenders to fit, not the route i want to go! I have a donor escalade i was going to swap everything but Im have second thoughts! tia
harpo231 02-24-2018 08:20 PM
Re: Frame questions
:wop::wop:
phattness 02-24-2018 08:31 PM
Re: Frame questions
you want pics for a value and lead for a chassis?
57taskforce 02-24-2018 08:43 PM
Re: Frame questions
If it’s a 4x4 frame I’m not that surprised. Thats kinda steep for around here but not out of the question. The 4 wheel drive frames are lots harder to find and when you do find them they seem to be more likely to be beat up.
phattness 02-25-2018 12:10 AM
Re: Frame questions
this one is 2wd and no title its a bit steep and the guy is :waah: because i questioned his price tag
tutone 02-25-2018 11:56 AM
Re: Frame questions
Sounds a little high at 1st but if you stop to consider you already have all your brake parts and a 5 lug rear and it is a shortie. I have seen them from 500 on up and they are headed up, as is anything that is factory short. I don't know what route you are going and like above, don't know if it is a 4x4 frame. Either way there are some saleable parts on it if you do decide to use your running gear.
phattness 02-25-2018 01:01 PM
Re: Frame questions
tutone great point that adds to the thought process for sure!! I would really love to find a k10 chasssis! i may stick the origonal plan of using the firewall, floor and chassis from my 06 escalade. that would make it awd with full modern suspension and hydro brakes.
Ironangel 02-26-2018 02:55 AM
Re: Frame questions
If that rolling chassis dont have a running motor with a shifting transmission then yes, way to much money especially with no title!
bs46488 02-26-2018 02:50 PM
Re: Frame questions
I think you are paying a premium for the SWB.
In my area a LWB frame is going for around $500 asking price. SWB in the same condition goes for around $1800 - 2200 (asking price).
Same thing is true for beds.
