just hit the donor truck Lottery
with the high winds keeping me awake last night I went truck shopping and found a complete 83 C10 Hello Power steering and Power front disc brakes for my 63 10 It has a nice 305 with a 4 barrel with header backed with a 700 R4 I will not be using
Re: just hit the donor truck Lottery
Cool.
I think there's a thread in here that mentions many of the things you want to grab off it before you take it to scrap. I know I missed many things I should have grabbed from my donor. |
further searching and answers to posts I found a kit that allows you to install the 83 axle under the 63 truck,, CPP parts # 6072RCK or 6372DRCK
seems its limited to a 3" axle tube, my guess is someone can fab brackets to fit a different dia tube anybody done this swap? |
http://67-72chevytrucks.com/vboard/s...d.php?t=651200 I bought some brackets from him for a 3.25" axle tube since I'm using a Ford 8.8 and I know he makes a few different sizes. |
Yes I do make 5 different size of trailing arm mounts.
http://www.67-72chevytrucks.com/vboa...d.php?t=620836 I don't currently have a panhard bar mount, but I am working on duplicating the factory '63-'64 mount. The 8.5" 10 bolt found under a '83 C10 will have a 3" axle tube diameter |
