-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Any Idea How To Remove these? (https://67-72chevytrucks.com/vboard/showthread.php?t=762370)
WannaBe68 04-22-2018 04:47 PM
3 Attachment(s)
I've been banging away at these little clips for the lower 4 panel screws with no luck. The skin even started getting pushed in a bit. And yes - I've soaked them with all kinds-of of break free stuff!
Any idea how to remove these things?
Thanks!
HO455 04-22-2018 05:35 PM
Re: Any Idea How To Remove these?
The doors of my 67 had this style of cage nuts in them. You might try looking at the backside with a mirror,. Who know what someone may have done it the past.
WannaBe68 04-22-2018 06:08 PM
In the top left picture - the arm rest mounting holes have those exact kind-of cage nuts. But these panel nuts look the same on the front side and backside. Almost like they were pressed in??
HO455 04-22-2018 09:18 PM
Are they stripped? If so maybe drilling and tapping them one size larger in place is the answer.
WannaBe68 04-22-2018 09:37 PM
Some have the screw broken off, but I have all new hardware including the cage nuts you showed. I sure would like to remove these and start over...
franken 04-22-2018 10:34 PM
They're welded on.
LockDoc 04-22-2018 11:08 PM
What he said.
Some are cage nuts some are welded. Looks like yours are welded. The cage nuts would be loose in the hole and you just squeeze the spring sides in to remove them.
LockDoc
vectorit 04-23-2018 10:06 PM
Welded to the panel
WannaBe68 04-23-2018 10:58 PM
Sorry about the focus - but the backside looks as square as the front side. I don't see any kind-of "welds"... Could they be pressed in? You guys know these ol' vehicles, so I'm sure I'm missing something!
Either way they have been playing havoc with me!
Thanks again for chiming in.
68SWB4x4 04-23-2018 11:04 PM
A couple of mine came loose removing the screws so I think a quick tap with a hammer and punch would do the trick...
vectorit 04-23-2018 11:19 PM
I think they are squished in, and then electrically welded.
When you get one that falls out, it looks like a simple square nut that has been squished. At least the ones in my looked that way.
HO455 04-23-2018 11:51 PM
You might try lightly grinding them with a small disc grinder until they are flush and try tapping them again. The smaller the disc the deeper into the nut you can get without hitting the panel. You might tape some shim stock around the nut to give the panel some protection as you go at it. Might work. Either that center punch them and drill and tap.
WannaBe68 04-24-2018 10:44 AM
I've been laying into them with a hammer and punch - so far it's been a big fat No-Go! Those badboys are "squished" in there nice and tight.
I'll break out the Dremel and a smallish cut off wheel and see what I can do.
Thanks again!
P.S. For basically a rust free Burb, that pic of the inside of the door makes it look nasty in there... might have to paint some POR15 in there before sending it out for paint...
WannaBe68 05-07-2018 10:02 AM
Since you are sitting on the edge of your seat waiting to see how this turned out -
I bought a drill and tap combo for the size of screw that goes into these nuts. Drilled out the broken off shafts stuck in the nuts and then taped the holes and then ran the tap through all of the holes. Some things you slap your forehead about and this was one of them!
W-A-Y easier than hammer and chisel or dremel and cutoff wheel. Way easier...
LockDoc 05-07-2018 10:09 AM
Good deal, glad you got the problem resolved. I have done it both ways. The ones that break out I have replaced with the plastic inserts for license plate screws. That also worked good.
LockDoc
HO455 05-07-2018 09:32 PM
Excellent!! Now it's party time!!!:ennyd::ennyd::ennyd::ennyd::ennyd::ennyd:
