Very nice 69-72 tach/vac cluster with wood grain
5 Attachment(s)
Here is one from the inventory that I put together. First off this cluster has a bezel made by Cheyenne Superman (Gary Terry). He does by far the best bezel work I have seen yet. I can arrange getting a matching glove box door insert that matches this wood grain.
Speedometer is a very nice OE that is spot on accurate, quite and no needle bounce. Tach is in my opinion marginal. It does seem to work ok after just a clean up. I have seen the needle stick before cleaning but nothing after. Fuel gauge is spot on also with test 0-90 ohm on my bench. I use a nearly NOS amp gauge in this one but could be converted to volt gauge. Ask me for the details if interested. The temp gauge is a new GM Restoration Parts unit that is spot on the the original OE temp gauges. I added the pink resistor for the ladies :) EDIT: I forgot to mention that the vacuum gauge is a OE gauge with a restored face. Upgraded oil pressure gauge to an 80 lb OE gauge. The tins are all bead blasted and painted. You all that know me will notice I have changed my tin color up a little. I like the new look over the old gloss grey. The lens is a nice OE that I polished on for a while. It came out just fine. These lens are getting so hard to find in a restorable condition. The rest is just the same passion we put into all of these clusters. Please note that I can swap this tach out with a more reliable aftermarket factory style tach for an additional $100.00 if interested. I am looking to get $600.00 plus shipping for this cluster. Thank you for the interest, Tom |
Re: Very nice 69-72 tach/vac cluster with wood grain
That's beautiful, Tom
Sold it!!!
As with all the stuff you do Tom - BEAUTIFUL craftsmanship!
B/R, Randy |
Very nice. Going to buy lotto tickets
