Overload Springs or Camper Springs axle bracket
Does anyone sell replacement axle brackets for the single leaf overload springs? I have a set however one of the axle brackets has stress cracks all the way across.
I see LMC sells most of the parts, but not the bracket I need. Their drawing looks different from OEM (bottom right on LMC catalog page below.) Bill https://i.ebayimg.com/images/g/10MAA...xl/s-l1600.jpg http://www.lmctruck.com/icatalog/cb/865w/0064.jpg |
Re: Overload Springs or Camper Springs axle bracket
At a glance it looks like LMC sells the spring only..but what you want and need is the landing pad plate-bracket for it that bolts into the rear diff./spring area assembly.
If you post a WTB (want to buy) ad in the parts section it shouldn't take too long for someone to respond. All good Coley |
LMC sells a two leaf and mine is a single leaf spring probably would still fit. Thank you, Bill |
