Alternator
What do I need to do to convert to an internally regulated alternator? I notice voltage is all over the place when the truck is running. I guess I could replace the voltage regulator but probably a good time to just get rid of it. 72 Special Camper with a 350 if that make any difference. Thanks
Re: Alternator
When I did mine, I bought a conversion engine harness from I think the Truck Shop. As well as the new alternator.
Re: Alternator
Re: Alternator
You can buy an adapter to change from old style to newer style connector on the back of the alternator. And a plug that goes on the wire leading to your regulator.
Install an internally regulated alternator, Delco 10SI, install both connectors as shown below. https://www.impalaparts.com/images/i...ts/27555-m.jpg |
Re: Alternator
Re: Alternator
There are a couple guides. Here's how I did mine.
12SI from some 80's GM car. 9:00 According to http://www.madelectrical.com/electri...elcoremy.shtml 12SI, 94 amp, at 9:00 (AC-DELCO # 321-269, Lester #7294-9) - Tell the auto parts counter person that “The alternator is for a 1985 Buick Riviera, 5.0L (307Y engine), with Heavy Duty options and Air Conditioning.” You have 3 wires. The big lug goes to the junction block with 8 or 10 gauge wire. The left spade goes to the brown wire that previously went to your voltage regulator The right spade goes to the junction block. This is a reference, so 16 or 18 gauge should be fine. I also used a ground wire. There is a ground bolt on the case, I attached the wire to the block there the alt bracket attaches. You can remove the rest of your voltage regulator wiring. There are jumpers that allow you to leave your factory harness unmolested. I preferred the simplified wiring, heavier gauge wiring, cleaner look. EDIT: Wanted to add that my alternator had a metric top bolt. 10 x 1.25? I had to grind the bracket for it to fit and be able to move. |
Re: Alternator
2 Attachment(s)
Here are the images of my install
Re: Alternator
2 Attachment(s)
Attachment 1815490 He'll also need this. Attachment 1815489 I would go with the CS 130 which is more plentiful. |
Re: Alternator
Re: Alternator
Re: Alternator
Re: Alternator
Re: Alternator
Subscribed, as I think I'll be needing this information soon.
Re: Alternator
Connect terminal #2 of the alternator to BAT along with the battery wire. Unplug the harness at the external regulator and connect terminal #1 of the alternator to the brown wire on the harness you unplugged. That's it. You don't need to buy a harness.
Re: Alternator
I wanted to clean my engine bay up and didn't like the old wiring harness hanging across my motor since I moved my alternator so I just eliminated the old harness and made my own.
I ran my hot wire to a junction block I placed on the firewall and from there to the hot post on my starter. I ran the control wire ( or whatever it's called) to the brown wire on the plug on my firewall. I then looped the sensor wire to the hot wire on back of the alternator. I was planning to move the sensor wire to the hot block on the firewall but never did it. Been running it this way for five years so don't see any reason to change it now. |
Re: Alternator
Look through the Post on the electrical section on here like the link posted by Vic vette
I first did this on my 68 30 odd years ago no forum went and pulled a sqb harness apart and seen what I needed to change on my truck and changed it to a 10 Si Now thinking do i want that 12 S1 in my new truck or upgrade it to the even better Cs130 Alt I have both are like new depends on which water pump I want to use as my cs 130 is a serpentine setup |
