-   -   1962 GMC Truck Nuts on the Interior Door (https://67-72chevytrucks.com/vboard/showthread.php?t=774749)
Dzhezzi Kampos 11-07-2018 06:37 PM
Hey guys!
Quick question, does anyone know if it is possible to find the interior nut plate that holds the door latch relay mechanism? There are three, but one of my old one fell out due to me messing with the bolt that goes through it, and I can't find it, I would like to weld on a new one.
Thank you for the help!
jbgroby 11-08-2018 09:59 AM
Re: 1962 GMC Truck Nuts on the Interior Door
do you have pictures? I have bunch of stuff, I may have it.
Dzhezzi Kampos 11-08-2018 11:51 AM
2 Attachment(s)
Yes, I do. I took pictures of the door with all three nut plates still in tact.
Dzhezzi Kampos 11-08-2018 11:54 AM
I hope the pictures help. All I found was the following for a corvette:
https://www.corvettemods.com/C3-Corv...4_p_13469.html
This provides a bit more info as to what I am looking for.
Thank you.
EDIT: I found this: https://www.classicindustries.com/pr...s/3784845.html
I really haven't ran into this issue before, but would this work? Has anyone ran into a similar issue before?
Thanks again guys!
The Rocknrod 11-08-2018 12:27 PM
1/4-20 Cage nut? - search for that name.
Mine look like they were pressed in and don't jiggle around like the arm rest cage nuts. I looked from behind also.
An option would be a cage nut or a nutsert. Either one would modify the hole in the door panel slightly.
https://www.mcmaster.com/cage-nuts (see Steel Snap-In Nuts at the end of the page).
This guy had a similar problem - http://67-72chevytrucks.com/vboard/s...02&postcount=3
Nutserts:
http://67-72chevytrucks.com/vboard/a...1&d=1418590066
There are also the hand drawn units: https://www.pegasusautoracing.com/pr...sp?Product=655
Harbor freight sells a cheap set up - https://www.harborfreight.com/45-pie...-kit-1210.html
Dzhezzi Kampos 11-08-2018 01:10 PM
Wow!
That can actually work! Let me give the cage nuts a try.
Thanks a ton!
Blue666(2) 11-08-2018 08:47 PM
This place has all kinds of nut & bolt arrangements. They might have it.
https://www.dixied.com/product3979.html
