Choke Question
3 Attachment(s)
Hi All,
I have recently purchased a 4x4 1969 Suburban with i6 250 ci engine. I will try to make it as stock as possible.. My question is about the choke. Looking to the carburetor, it looks like it is an automatic choke. And as far as I have read on the forum and owners manual, this is the standard automatic Rochester carburetor. But also I have a pull type switch (looks like the choke switch). Is this for the choke? Is my carburetor aftermarket? (Or is the button/switch?) Thank you in advance.. Regards Sinan |
Re: Choke Question
Welcome Sinan!
Yes your carb has been changed to an automatic choke type. Originally it would have been a manual choke type. The choke/switch is stock. It’s just a cable connection to your carb. You need some more parts on your intake and carb to make that carb work correctly. You can adapt a manual choke kit to that carb or if total originality is needed you’ll need to find a correct carb. Take some more pics for us. Not closeups like you have now. And here’s a link to some pics of what your carb should look like. https://www.google.com/search?tbm=is...10.r45zXc0WsRY |
Re: Choke Question
3 Attachment(s)
Hi,
Sorry for delay.. i had some trouble trying to take and resize pictures.. So i think i have to either add a manual choke/find stock carburetor(might be difficult here) or fond missing parts for the auto choke so that it works corect? Here are the pictures, hope they are okay.. Thank you! |
Re: Choke Question
Very good pics!
Your intake doesn’t have the parts on it to hook up your carb automatic choke. And your carb doesn’t have the parts on it to hook up a manual choke. You either need a new intake or a new carb. Neither one is a good solution. A new carb doesn’t come with the bracket you need to hook up the choke cable. A new intake won’t come with the automatic choke parts. I’ll post a link to what your choke should look like. You can get choke conversion kits that will allow you to hook up your existing choke cable to your carbs automatic choke. One like this. It comes with a new cable too. https://www.ebay.com/itm/Dorman-Help...-/142978536692 Here’s the link to pics of what your choke should look like. https://www.google.com/search?tbm=is...10.r45zXc0WsRY Let us know what you’d like to do. |
Re: Choke Question
actually, does a 69 have a manual choke? the choke knob stopped being in the dash in 1968.
I may be wrong, ive only owned 67 ad 68`s but im pretty sure theres no choke knobs in 69-72 |
Re: Choke Question
Mine is 1969 and there is a choke button. I am pretty sure because VIN number mach and Chevrolet letters are on the grille..
Re: Choke Question
Re: Choke Question
That would be the best thing to do.
There are some on eBay in England. Closer too you than the US. https://www.ebay.co.uk/sch/i.html?_f...&_sacat=163145 |
Re: Choke Question
Let us know if you find a kit.
Re: Choke Question
I will buy the Dorman Help 55101 GM Choke Conversion Kit that you mentioned. Evnthough there are mixed reviews on the kit ( mainly difficulty on installation and that they might need to cut the bracket) this is the cheapest solution ( and I dont know any other solution :) ).
They are available ar Rockauto where I buy my parts. from. So this will go into the shopping cart, as soon as I order more parts.. Thanks for your help! |
Re: Choke Question
Excellent!
With a manual kit you won’t need the linkage and vacuum pot that your carb has now. When you remove it remember to plug the vacuum port it’s plugged on to. Best of luck to you! |
Re: Choke Question
Just arrived!!
Re: Choke Question
Excellent!
If you encounter any more problems hooking it up be sure to ask. And pics once you do get it on would be nice. |
Re: Choke Question
4 Attachment(s)
Hi,
When attempting to install the manual choke, i realised that there is a vacuum line coming into the lower port of the carburetor from the distrubutor (i forgot to say it was converted to electronic ignition). Then there is another line coming from an upper port of the carburetor to the vacuum diaphram valve, that supposed to control the choke. So i am thinkng... maybe instead of the thermo receptor at the intake valve, is the choke controlled by the electronic ignition?? Either way it does not look like it is opening/closing the choke, because even with the valve is closed fully or open fully, that does not pull/push the choke rod, as it is not hooked correctly, the connections are loose.. Maybe that was the main problem of the choke not operating correctly? Can you please suggest what i shall do? I have also found an earlier type carburetor that was removed feom the PO, so they might have upgraded to automatic choke when upgraded to electronic ignition (which i have no clue about how it works, as its too modern for me!) Pictures below.. |
Re: Choke Question
Vacuum valve
Re: Choke Question
There’s a pic in here in post #11 of how an automatic choke works. It has a choke stove and linkage rod. Your intake doesn’t have that.
http://67-72chevytrucks.com/vboard/s...d.php?t=416118 The distributor vacuum line doesn’t control your choke. It’s for your vacuum advance. You need to remove the choke pot on yours and plug that port. |
Re: Choke Question
Re: Choke Question
That is correct.
Re: Choke Question
4 Attachment(s)
Okay.. Now the choke is installed and here comes my comments and pictures..
1) The installation is very carburetor specific.. It is basically a long wire with sleeve (like proper choke cable, (but I could not use the sleeve, but used the sleeve that was on the truck, because the hole on my dash was a larger diameter). It is longer than needed so no problem there.. 2) You supposed to drill a hole into the choke shaft and attach a double-L type bracket using the washers and screw provided where you hook the cable to... As my carburtor already had a choke, I only took the part that is attached to shaft and attached the bracket using the screw that is already on the carburetor... 3) The biggest challenge is to use a god position to attach the big L type bracket that is provided.... After spending hours and different setups, where the best was the carburetor attachment bolt on the intake manifold, I still was not happy and I decided to make my own bracket and using it.. I still attached a picture of the setup that supposed to work ( which I was not happy) |
Re: Choke Question
4 Attachment(s)
Better pictures:
If you ask me that set is not very usefull. I would like to use a choke cable with nicer switch on the dash.. And only used the small bracket that is attached to the choke shaft and the two piece that holds the wire.. (which can be found in any hardware store) So nothing special... Though I would never think of such a conversion if I haven't bought the kit! |
Re: Choke Question
That’s the problem with those kits. They come with a bunch of parts and you get to use whatever works.
Sometimes you need to make your own brackets. Sometimes you need to make modifications several times until you’re happy with the result. Keep at it until you’re happy! |
Re: Choke Question
Thank you for all your support..
i have tried to include as many pictures as i can to help people with same problem like me.. Regards Sinan |
Re: Choke Question
Excellent pics. If you want to use your new cable that is too small for the hole in the dash just look for some washers like this that are large in diameter but have a smaller centre hole. https://www.screwsandbolts.com/AN-St...rs-p/34182.htm |
Re: Choke Question
Actually i thought using my old switch but could not clamp the new wire in.. Maybe i can get nicer knob, cut the old one and epoxy the new one instead? |
Re: Choke Question
You could use a washer front and back.
If you don’t like shiny ones look for black ones. https://www.allparts.com/AP-6691-003...ock_p_488.html When I’m looking for different washers or brackets and stuff like that I browse around the plumbing or electrical sections at the local hardware store. You’d be surprised what you’ll find. |
