NSS for transmission
Something I never looked into or read ... but its where I am up to on my build.
I assume on most swaps you keep the OEM NSS ?? As it plugs directly into harness. Any other considerations or thoughts here .... any links to a good page that discusses this ? thanks I have a NSS on the stick shift floor mount shifter ... is all. |
Re: NSS for transmission
I use the one on the transmission just because you dont have any adjustment issues that you can have with the older column mounted ones, something inherent is 45 year old technology not to mention wear. Fairly simple to use it, but does require a starter relay. Here's a thread another member made a while back. http://67-72chevytrucks.com/vboard/s...d.php?t=774466
Thanks nova !!!
I've never used one on my trucks, psi harnesses dont have it.
