-   -   Amazon aluminum radiators?? (https://67-72chevytrucks.com/vboard/showthread.php?t=779358)
RPBurris 01-11-2019 10:55 PM
Curious if anyone has tried purchasing and running any of the aluminum radiators from Amazon? There are multiple options that "claim" to fit 69-72 trucks with options from 2-4 rows and with or without electric fans included. They look shiny but curious how they perform. I am in the market for a new radiator anyway. I searched the forum already and did not see anything recent for these. For some reason I cant paste the link correctly so below is a photo. We all like photos anyway.
p0508 01-11-2019 11:39 PM
Re: Amazon aluminum radiators??
To a certain extent you will get what you pay for. The most budget option I have found but still retaining a decent company/warranty was cold case radiators. After that you move into one off handmade US companies like entropy/R&D fab etc etc whom obviously have to charge more than an assembly line large company. As far as most of the chinese amazon and ebay stuff I'd stay away. The lowest I would go is cold case for a name brand. I've used their stuff in the past and it worked as advertised with no problems and at least I have someone I can call if i have a problem.
-Drew
dmjlambert 01-12-2019 09:56 AM
For ordering online I like Engineered Cooling Products.
http://www.speedcooling.com/1967_197..._Radiator.html
This was a radiator that came up as recommended numerous times here on the forum, so I decided to go for it. It has worked well for a couple of years now.
I ordered a zinc anode for it from Amazon. https://www.amazon.com/gp/product/B001GR09S4/
leddzepp 01-12-2019 10:22 AM
I have Champion radiators in both of my trucks. Yep, they are inexpensive and made offshore but the one in my 72 has been there for several years now with no issues and the one in my 68 has been just over a year, no issues. Both trucks run factory AC all the time, summers are triple digit temps and often times sitting in traffic. I would buy another one without hesitation.
1971Stepside 01-12-2019 11:03 AM
I just purchased the Cold Case after deciding that a grand was ridiculous for a radiator. On the plus side the Cold Case is a work of art and well manufactured with a great warranty and price. Downside is that it doesn’t just drop in. It is worth a little fabrication for me to save 500 bucks.
Greasey Harley 01-12-2019 05:51 PM
My truck came with a Champion radiator that looked brand new.
A month later, it started leaking.
I took it to the local radiator shop and they told me that it was leaking where one of the tubes was glued into the core. It was un-repairable.
I threw that hunk of junk in the scrap aluminum pile and bought a different radiator.
I was not impressed.
jcwren 01-12-2019 06:01 PM
I bought mine from Rockauto. It said it's the correct fitment for the truck, and it kinda is. I have the 250 L6, and I had to move the battery side upper and lower radiator support bracket to the outer position. However, as a result, I can't run a radiator cap with ears, because it'll hit the bracket. I haven't had any real success finding an earless cap, so I'm making one. I figured it was a good reason to buy a jeweler's torch, so I can trim the ears and braze the edges :)
Going back to the actual radiator itself, the quality is really good. It's unpainted aluminum, and it's whatever the larger number of tubes is (3 vs 2, or 4 vs 3, I forget). But it'll work if I do a SBC or LS swap.
KQQL IT 01-13-2019 01:13 PM
No ears per the photo.
https://sdparts.com/i-24089893-acdel...-cap-rc32.html
jcwren 01-13-2019 09:59 PM
Well, that's pretty cool, and I appreciate you finding the link. However, the $20.73 shipping on a $9.79 item means they're out of their freakin' minds.
Elliot949 01-13-2019 10:28 PM
3 Attachment(s)
I am running a Champion radiator in my truck...
my67c20 01-14-2019 12:05 PM
Swapped manual to auto and went with one from Entropy. Got it with the controller. Had to do some harness wire shortening, but otherwise nice unit. Needed the HD mounts for the radiator, but probably could have used the stock, but failed to mention that at time of order. Brothers had the mounts, so not a big deal. Worth the price.
