1966 Chevrolet truck C10, 327+TH400
Hi,
Restoring a chevy truck -66. I am having trouble finding the correct grommet/floor hole cover for the lower 2 holes in the firewall/cab. The holes are each about 1 3/4" x 2" and are located on the driver side near the gaspedal, and one on the passager side. Does someone know what product will fit and where to find them and what they are for (clutch?) Thanks! /parzimmedahl |
Re: 1966 Chevrolet truck C10, 327+TH400
Firewall hole identification - http://67-72chevytrucks.com/vboard/s...2&postcount=91
The only plug I know of is from the next gen trucks - https://gmcpauls.com/auto.transmission.htm That doesnt mean there isnt one for our truck though, someone else may know better. |
Yes, that would be the clutch rod hole, one on each side of the trans hump.
I will check with GMCPauls to see the dimension of the 67-70 delete plug. Have anyone seen this plug for 60-66 trucks? |
3818134 plug , clutch 1963-66 pg , th...pedal push rod plug
Not the same part number for 4wd
| All times are GMT -4. The time now is 01:45 AM. |
