-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   SM465 with M10x1.00 thread for shift knob? (https://67-72chevytrucks.com/vboard/showthread.php?t=781189)
mattfranklin 02-09-2019 06:32 PM
Original shift knob was aluminum and half jammed on when I bought the vehicle.
Shaft measured 0.374 and thread looked very fine so I bought a 3/8-24 nut to test fit. Did not fit.
So I bought a couple of metric nuts: one was labeled M10x1.25 and the other was labeled M10x1.00. The fine threaded one fit perfectly.
Now I cant find any shifter knobs with an M10x1.00 thread.
I'm now wondering of the hardware store bin was mislabeled or if I do really need the M10x1.00 and they are just hard to find.
Any ideas? I have a proper thread gauge somewhere and may need to dig it out.
Keith Seymore 02-09-2019 09:04 PM
Re: SM465 with M10x1.00 thread for shift knob?
You can probably run a tap into the existing knob and clean up the threads.
I did that with my MY6 shift knob. The shaft was fine thread and the replacement knob (a transfer case knob) was coarse thread . Ran a tap in it with no problem.
K
Keith Seymore 02-09-2019 09:05 PM
Another option would be to drill the threads out and use the appropriate heli-coil insert.
K
kwmech 02-09-2019 11:06 PM
Never seen a metric 465 shifter
mattfranklin 02-11-2019 12:22 PM
Thanks, guys. Maybe just I'm fooling myself with the M10x1.00 nut. Its dimensions are so similar to the 3/8-24 that it's not even funny. And maybe with a little more chamfer clean up the 3/8-24 will fit.
mongocanfly 02-11-2019 12:28 PM
A thread gauge is what you need...that 10mm is larger than 3/8...that may be why it threads on so well.....
get a 3/8-24 die and chase the threads and you should be good...
mattfranklin 02-12-2019 11:33 AM
I love this board. Excellent info.
I was concerned that if someone had swapped in a newer SM465 it might have had some metric in it, but based on your info and guidance I'll run a 3/8-24 die down the threads. I would have hated to risk doing that if it were really a metric or vice versa.
I think I might already have one in my tool box. I bought a bunch when our local hardware store (OSH) went out of business.
mattfranklin 02-18-2019 01:33 PM
Thanks for your help, guys!
I ran the 3/8-24 die down the shifter threads this weekend. I was careful to keep it perpendicular, which was kind of hard. It felt a little tight at first and then got easy the rest of the way down. Then I was able to spin a 3/8-24 nut up and down the threads with ease.
Then I ordered a proper round shifter ball. eBay even had one with the correct SM465 shift pattern. I hope the quality is ok, because sometimes eBay is sketchy.
mongocanfly 02-18-2019 06:17 PM
sweet...glad it worked out for ya
mattfranklin 02-23-2019 02:43 PM
All is well. Glad I could find one with the shift pattern because I plan to teach family members to drive a stick with this truck.
scott123 02-26-2019 09:29 AM
A little late to the party but glad it worked out.
I had the same problem some years back when I was adding a lawn mower piston as a shift knob on an old mud truck.
I fitted the 3/8 nut to the underside of the piston and then it did not work.
Like you, I ended up chasing the threads and then it worked like a dream.
Scott
