66 C10 Seat Track to Floor Bolt Size
Looking for the correct bolts to mount seat track to the floor
Thanks |
Re: 66 C10 Seat Track to Floor Bolt Size
5/16"-18 usage goes back into the 50s. I can go get an exact length in a minute. 1/2" Long flange head with a star washer.
Same bolts I believe that fasten the track to the seat frame. Stole all my bolt from the underside of another seat. Shiny!
Bolt Barn on eBay has 5/16"-18 Flange Head bolts by the way. ;) |
According to an American parts book. 5/16-18 . 3/4" long with a 3/8" hex. washer head ( non Standard ) incorporated star washer. Cadmium plated . POINT D which is self tapping 442751 0riginal part number. This is the closest I can find after checking mine on 3 1963's.
Comparing the parts book to the Rocknrod example , they must consider overall length of 3/4" not the standard measurement of under the head to end of screw. Therefore if you want bolts that will fit the correct dimension would be in the 1/2" range as stated. A 5/16 bolt would have a 1/2" hex head usually. Thread diameter plus 3/16 is the usual head indicator in the smaller bolts.
Now days it's hard to find a captured or incorporated star washer flange bolt. At least I haven't been successful.
https://www.ebay.com/sch/m.html?_odk...F2%22&_sacat=0 https://www.boltdepot.com/Flange_bol...l_5_16-18.aspx Maybe Avueco? But i'd have to go get a cup of coffee to search that catalog. :) |
Thanks everyone!!
