-   -   A Pillar Rain Gutter Delete (https://67-72chevytrucks.com/vboard/showthread.php?t=782191)
slorio 02-25-2019 01:21 PM
Folks:
Interested if there is any downside to removing the rain gutters that are spot welded to the A pillars on our trucks? Took mine off to address rust underneath while painting the door jambs. I like the look without them, but was wondering if there is any downside from those who have deleted?
Thanks,
Steve
https://lh3.googleusercontent.com/n2...0=w165-h220-no
BR3W CITY 02-26-2019 09:55 AM
Re: A Pillar Rain Gutter Delete
The first time you open your door after a rain, your knee gets wet. Other than that, removing the trim will leave the little studs/rivets where it attached, which will look a little out of place if they arent' removed.
The Rocknrod 02-26-2019 10:50 AM
I wonder if anything would it do to wind noise?
dracko 02-26-2019 12:03 PM
Would probably reduce wind noise haha. I epoxy primed and reattached mine with panel adhesive to hopefully prevent future rusting.
nsb29 02-26-2019 08:53 PM
Ditto I didn’t like the gaps and the alignment of the A pillar and the door glued it back
