-   -   New project (https://67-72chevytrucks.com/vboard/showthread.php?t=783125)
SeanB242 03-11-2019 08:00 PM
New project
Picked up a cab and short bed to go on my frame. Getting ready to start stripping the frame for blast and powder coat. Starting from the ground up. Gonna be a long road.
rjs53 03-11-2019 10:49 PM
Re: New project
Throw money at it like its going out of style, then the road wont be so long.:metal:
SeanB242 04-01-2019 09:09 PM
Re: New project SixEight
3 Attachment(s)
Always trying to save money, I bought a c-notch off eBay. Of course things didn’t quit line up right. After some debating on a return, I just grabbed the cutoff wheel and went to town. I like my version better than the plate on the outside of the frame anyway. One side done and other started but ran out of time. Got a couple ideas on a rear mount tank also. Trying to get all this lined out before powder coat.
jocko 04-01-2019 10:00 PM
Re: New project
Sean, I hate to say it, but that plate you removed from the outside was providing at least some level of structural rigidity. If picture #3 represents the finished product (except for finish welding), then the frame is only as strong as the thin cross-section at the top of the C-notch - and that's not very strong. Personally, I would consider adding back in some structure.
SeanB242 04-01-2019 10:19 PM
Re: New project
Thanks jocko. I just moved the plate from the outside to the inside of the frame as seen in the first picture. Same concept, different method. You can’t see the the plate inside the frame in picture 3. I think it will work but open to suggestions.
jocko 04-01-2019 11:37 PM
Re: New project
Got it Sean - thanks, I thought it was missing completely!
SeanB242 04-02-2019 02:41 PM
Re: New project
Anyone on here familiar with these springs?
SeanB242 05-01-2019 03:19 PM
Re: New project
3 Attachment(s)
Getting closer to powder coat. Still a few things left to do. Got the rear tank mounting lined out now I’m looking at the frame mounted battery tray and air tank. I was gonna lay out my hard fuel line also so my mounting holes for clamps are there, also I don’t have my brake lines yet. Should I just do the big stuff and wait on the lines until it’s coated and paint any holes I have to drill? Trying to get everything lined out and mounted before powder.
Click this 😂
SeanB242 05-03-2019 09:26 AM
2 weeks off work so i got lots of time, but not knowing what my medical bills will be, im trying to find things that wont cost anything. So i started the cowl section of my cab. Im sure ill catch some grief for cutting the rain gutter out of my cowl but it was going to have to be replaced anyway, and I want a smoother look. This truck is going to be far from stock so, no harm right? Just as i suspected, the more I dig in the more bad spots i find. all the outer rust is gone now but the inner metal under the dash is getting some spots replaced.
Watch This
Ganty101 05-03-2019 10:24 AM
Re: New project
I’ll be keeping an eye on this. Very interested to see where you go with it all :) plus giving me ideas for when mine needs work (hoping that’s a few years away yet though!)
Keep you the good work!
SeanB242 05-03-2019 09:11 PM
Re: New project
Thanks. It’s probably going to take a while. Spent all my mad money on body parts so I’m starting over on my powder coat funds 😂
SeanB242 05-04-2019 12:04 AM
Re: New project
2 Attachment(s)
If anyone has been watching my YouTube channel you’ve seen I been working on my firewall/cowl. It’s like an onion, every layer I peel back I find more things to fix. I went deep this evening. I was just cutting out small sections to replace but that got out of hand real quick. Oh well. Do it right or not at all, it should last another 50 years or more I guess. Anyone ever use the paint or rust neutralizer from Eastwood. I want to put something all over the metal under the cowl and inside the firewall.
SeanB242 11-10-2020 01:02 PM
Re: New project
2 Attachment(s)
Update! 2 part Summit brand paint. Easy to use. We’ll see about the durability.
SeanB242 11-12-2020 11:09 PM
Re: New project
2 Attachment(s)
Waiting on my brake kit to come in. So installed my new lights and built a temporary box to blast small parts in. At least it’s a little productive. 😬
LockDoc 11-12-2020 11:43 PM
Re: New project
Parts look good. I have a '67 cab that looks like that. I decided to just scrap it. I don't mind a little challenge but that's more than just a little..... I applaud you for your enthusiasm and hard work...:flag:
LockDoc
SeanB242 11-13-2020 01:33 PM
Re: New project
LockDoc
Thanks. Thoughts crossed my mind. At this point it’s just going to be replacing the metal. At least I know what I have. I’d prob just be in the same boat if I found another close enough to me.
gmc684x4 11-13-2020 03:08 PM
Re: New project
Nice start to your truck
What are your plans for motor tranny combo ?
SeanB242 11-13-2020 03:27 PM
Re: New project
I have a fairly stout 355 that’s running or 90’s big block. Prob just throwing the SB in so I can drive it. I have a 350 turbo but I’d like to find a 700 for the OD.
