-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   MI Zinc Plating. (https://67-72chevytrucks.com/vboard/showthread.php?t=785472)
cucvzuz 04-21-2019 12:29 PM
Zinc Plating.
I am sending some parts in to be zinc plated. I only have a few parts and the company will do just one part but tgey charge a $150 minimum. I have had a few things done in the past and it takes alot to go over the minimum.
If you have anything you would like plated post what you have.
To help cover the cost I'm asking $10 for a small flat rate box and $20 for a larger flat rate box. You can ship me the parts with a return label and as soon as they are done ill send them back to you. Turn around is usually about a week.
Id like to send in parts in 2-3 weeks.
Frank
70STOVEBOLT 04-21-2019 05:22 PM
Re: Zinc Plating.
What are you having plated? I have some door hinges I would like to have plated. Do they have to be ready to plate?
cucvzuz 04-22-2019 08:08 AM
Re: Zinc Plating.
I'm sending in the rear gate and hatch strikers from my Burb and tailgate straps along with some bolts.
How large are the hinges? Yes they will need to be plating ready. I will be stripping all of the old zinc off my stuff before I send it.
70STOVEBOLT 04-22-2019 11:35 AM
Re: Zinc Plating.
I meant door hinges not dope hinges. I would also like to to do the door strikers and bolts and tailgate hinges and trunions and hardware. Did you get a quote for the parts you are having done? I would like to have an idea before I send them.
cucvzuz 04-22-2019 01:52 PM
Re: Zinc Plating.
PM Sent
AASmedic 04-22-2019 10:28 PM
Re: Zinc Plating.
Frank
Hey Frank,
I have some original hose clamps that could use re-plating. PM me your info and I will send them to you. Thanks for the offer to do this.
Kevin
