-   -   Power Steering Pulley Install? (https://67-72chevytrucks.com/vboard/showthread.php?t=786854)
Dodge68charger 05-14-2019 09:59 AM
Do I Need a Special Tool To Install The Press On Power Steering Pulley or Can i use a Bolt and Washers to Tighten it Down? Thanks
Big Kev-O 05-14-2019 11:42 AM
Re: Power Steering Pulley Install?
Mine went on with a bolt, only need the puller to take it off. I would make sure to use a grade 5 or even 8.
dondb 05-14-2019 12:10 PM
^ What he said:)
MARKDTN 05-14-2019 03:22 PM
The right tool goes a long way. But If I were going to do it without, I would put the pulley in the oven at maybe 275-300 for 20 min or so, and the pump in the freezer overnight. If you are fast, you might get it most of the way on without a puller tool kit.
franken 05-14-2019 07:33 PM
Considering the tool is free to borrow from a parts store, why risk damaging the pump or pulley?
Mike C 05-14-2019 09:30 PM
Harbor Freight has one for about $20. Buy it once and have it for the next project, no special trips required.
