Mustang II help...
Bought this unfinished project 10 years ago, 51 truck, already had must 2 front on it, was told it was either a fatman or something...anyway, does this look like a stock setup ? Maybe pulled from a parts car? Not that thats a bad thing but, in the pic, circled in red, the joint moves about 1/4” without moving the driver side, is there an adjustment forthat? Otherwise i think im looking at having to replace the whole power rack? Suggestions? Alsooooo,
To get the height i want im thinking i need the 2” drop spindles,,any sugestions? Would also like to upgrade to the 11” gm rotors at the same time.. http://67-72chevytrucks.com/gallery/...88FE367A88.png http://67-72chevytrucks.com/gallery/...2D23CB409.jpeg |
Re: Mustang II help...
That MII setup is using stock style arms, but Fatman and others sold MII setups with stock arms. You are missing the strut rods to go along with those stock style arms, donor should’ve had them and if it was a kit it would’ve come with them. Somebody left them off.
Racks are maintenance free, no adjustments available as far as I know. No idea on sizing or sourcing a replacement. There’s gotta be a measurement you can take to get another though. Worst come to worst, find a rebuilder and have yours rebuilt. Sorry no idea on the spindles or brakes. |
I don't have a pic of the orginal set-up, but here is a link to what Heidt's sales now. https://www.heidts.com/search-results/?keywords=sr-101. Hope this helps ...Jim |
Do you mean there is 1/4" of slop in/out under the boot inside that red circle? If so, thats a bad inner tie rod end. It probably isn't adjustable, but it probably is replaceable. Take the boot off and look.
SInce its a power rack, I wouldn't be in a big rush to repair it until you know the rack is good. There is all sorts of crap that can go wrong with a power rack. |
Good info, thanks,
Oops. Didn’t realize the strut rods went from the arms to the rear on the Mustang II. Must have been remembering a different vehicle where the strut rods go to the front of the vehicle.
The racks are non adjustable on the inner tie rod, BUT, I have seen them get loose. This is a threaded coupler. You can pull the boot back and see if it is loose. - tighten to 75 ft/lbs. Other than that, new rack. 74-78 Mustang was the base doner from the picts. For dropped spindles, No Limit has a "Smart Spindle" MII based, 2" drop, the brake side thinks it is a metric GM (G-Body), so the spindle pin and caliper mount are spec of the OE gm. You can put 11" GM rotor/cal/pads/bearings/seals directly on the spindle. No adapters or bolt-on mounts. 139/pr
