-   -   65 Wheel/Tire Size post Axle Swap Guidance (https://67-72chevytrucks.com/vboard/showthread.php?t=793006)
Magicalzoomer 09-05-2019 04:50 PM
Hi Guys,
After swapping to an 84 suburban axle, I need to get larger wheels to fit over the larger rear drum.
My goal is to have them as close as possible while still being able to fit under the body without rubbing. From what I can tell, it is a 4 inch backspace on the rear and 5.5 on the front, does that sound accurate?
I had an 11 inch wide 15 on the rear but it stuck out from the body by about 3/4 of an inch. I was thinking a 10 wide 16 or 17 with 4 inch backspacing would fit correctly.
Bottom line:
I really like the wheels/tires/suspension set up on the beautiful truck below. Any rough ideas of what sizes this guy might be running? Sadly, I cant find any info on who built it.
Youtube
https://www.youtube.com/watch?v=HUXyJRX8LvI
Thanks for your help guys!
350TacoZilla 09-06-2019 04:51 PM
Re: 65 Wheel/Tire Size post Axle Swap Guidance
Not understanding why you need "bigger wheels" to fit over the drum. If I'm remembering correctly square body suburbans would have came with a 15" wheel with either 4" backspacing for the 5 lug or 3&5\8" for the 6 lug. I have both available to measure if you want but the 4x4's are still bolted to a truck so they might take me a bit longer lol.
On the truck in video its no wonder you cant tell what wheels they are since the camera never sits still or get a full side shot but they look like they might be the knockoff's of crager soft 8's with a factory 4x4 rear center cap all around or maybe the late 80's early 90's aluminum wheels from a chevy 4x4 blazer\suburban that have been painted black .
350TacoZilla 09-06-2019 05:16 PM
5 Attachment(s)
There are tons of different companies making the black steel wheels with the 8 holes in them like cragar,pro comp, black rock, summit racing wheels (made and now sold by vision wheel I think) that look very similar to that black trucks wheels but some have smaller or larger holes depending on brand and sometime diameter. Ill also grab a pic of the stock alloy I mentioned.
the Order I put is
Cragar Soft 8 - Vision HD 85 - Pro Comp 97 - Pro Comp 98 - stock GM alloy
Magicalzoomer 04-11-2020 09:50 PM
Yo 350,
Thanks a ton. That’s exactly what I’m looking for. It may have just been the negative offset on the old wheels I had, but the drums wouldn’t fit in those 15s. I just grabbed some stock 16 8 bolt wheels from the yard, but I will dig into measurements once I get discs up front. It seems like both the axle swap and discs up front will widen the stance a bit, but I am not sure how much. Thanks again.
SCOTI 04-13-2020 09:54 AM
The Squarebody Burb rear end housings w/HD brake option drums won't allow bolting wheels on w/a deeper than factory back-spacing because the inner barrel of the wheel won't clear the outer edge of the drum. Stock width 15" wheels work just fine. If you want a wider wheel w/increased back-spacing so it fits under the sheet-metal, you have to increase the wheel diameter or swap the rear brakes over to a standard C10 rear drum set-up.
The truck in the video looks like its using standard wheel sizing so prob 15x8 w/4"BS.
