PBFab frame stiffener
Has anyone used the PBFab frame stiffener with a RideTech strongarm rear coilover setup?
Posted via Mobile Device |
Re: PBFab frame stiffener
Bump
I don’t have the frame stiffner but I do have the rest of the PB front and rear suspension. What are your concerns or questions?
I’m wondering if the ride tech trailing arms will mount to the trailing arm mounts on the frame stiffener. Like is the spread on the mounts the same?
That being said, if one or the other required custom rear-end mounts to compensate for some sort of design change, then I would be hesitant. If both set-ups work w/a factory T/A rear end, I would think you'll be ok. |
