-   -   Backing up with a tow bar (https://67-72chevytrucks.com/vboard/showthread.php?t=794353)
dmjlambert 10-02-2019 08:24 PM
When I remove the engine from my truck, I would like to roll the truck out of the garage and power wash the engine bay. I have a list of things I want to do with the engine and the engine bay while the engine is out.
When it comes time to put the truck back into the garage, which is uphill, I was thinking of putting this tow bar on it and use my SUV to back the truck into the garage. I understand these trucks track fine when going forward. Should I expect it to be a different story and big trouble to back it up?
It is a 1969 CST/10 pickup with power steering and manual brakes.
Keith Seymore 10-02-2019 08:37 PM
Re: Backing up with a tow bar
3 Attachment(s)
I don't know; I don't think I've ever backed up with a tow bar.
I don't think it will be too bad since it's just a one-shot deal. I imagine you will be going slow; you would be able to stop and straighten it up with the floor jack or by steering the wheels of the towed vehicle.
I have a lag bolt in the post in front of my repair stall. That allows me to pull any disabled vehicle up in the garage with the come along.
K
BigBird05 10-02-2019 08:53 PM
I did that with mine. Not to bad as long as it is going straight back. Helps if you have a second person steering the truck while you are backing up.
lutronjim 10-02-2019 09:05 PM
Might tie up steering wheel like the wrecker guys do if you by yourself.
truckster 10-02-2019 10:05 PM
I would have someone behind the steering wheel making sure it tracks.
Steeveedee 10-02-2019 10:36 PM
Either of the last two replies are great, if you don't have someone to help. Backing with a tow bar (or even towing forward when turning sharp corners) has to be done carefully.
dmjlambert 10-02-2019 10:54 PM
Are there any special considerations or problems I could have with unpowered power steering?
davischevy 10-02-2019 11:32 PM
It shouldn't be a problem with the steering. As said earlier, you will need someone behind the wheel or tie the wheel down. I tow a Jeep behind our motorhome and if I back up far I have to do one of the above.
Ironangel 10-03-2019 12:27 AM
It should work quite well because the tow bar is a solid connection allowing the push vehicle to become an extension of the non-motor vehicle. I'm doing the same maneuver with one of my 72's but instead of a truck with a tow bar I use a Ford 8N tractor with a 3-point boom. I have also used a snatch block anchored to the shop floor and use a winch. A positive connection on a sloped or inclined surface is probably the safest way to move that truck. If you don't have a co-pilot to help steer, a couple of ratchet straps will hold the wheel. Tow bar should work and work well, just take it slow and easy...
HO455 10-03-2019 02:18 AM
The shorter the wheelbase on your tow rig the better in this situation. I've backed up cars on tow dollies with my S10 Blazer. I would not even attempt it with my Burban.
One other note if you have power steering you need to loop the hoses or make other provisions to catch the fluid.
