-   -   Old Subject-New Thread (https://67-72chevytrucks.com/vboard/showthread.php?t=795195)
35boulder 10-19-2019 04:46 PM
2 Attachment(s)
So I was reading thru a bunch of old threads about what is the correct antenna for one of our trucks. Single mast or extended? And my radio is an AM only. Below is what is on my '69 and I'm sure it is NOT original, but most of the info I read on earlier threads was about '71-72 year.
The base on my antenna appears to be for an extended one so, would mine have originally been an extended one (without the spring function) or a single mast.
Appreciate any info. Thanks
LockDoc 10-19-2019 08:25 PM
Re: Old Subject-New Thread
The base looks original so I guess someone just put the spring mast on it. I think it should have the adjustable one on it but I'm no expert on antennas...... I will look closer at my '68 in the morning, it has the original antenna on it.
LockDoc
FirstOwner69 10-19-2019 09:14 PM
A telescoping mast is correct for a '69. Here's a picture of the base and bottom of the mast that are original to my '69.
As Leon said, your base is correct.
Astro-Balls 10-20-2019 02:57 PM
What is original for a '68?
