New Member
Hi, Bob here....
I've just acquired this 66 GMC Suburban. I have started the tear down. My plan is a 4x4 conversion, any suggestions are welcome. I'd also like to switch to rear Barn doors if I can find a set. Bob :gmc2: |
Re: New Member
Welcome....should make a sweet ride...
I would look for a good set of axles and drivetrain from a square body truck...I'd try to stay away from the fulltime 4x4 yrs....what engine and trans are you planning?...also your chosen tire size and axle ratios will need considered |
Re: New Member
Here is a 3/4 ton 44 I narrowed a few years back using stock shafts from different axles. It was for a 48 Ford F3 I converted |
Re: New Member
Sounds like this isnt your 1st rodeo....you might squeak by without having to narrow a set of axles..you can run a more positive offset wheel to counter some width...that's what I did on my 57 IH...I went with USWheels with stock style wheels...
Re: New Member
Welcome! I look forward to following along on your build.
Re: New Member
Welcome to the forum Bob :D Are you the one in Pocatello?
Here is the good thread on converting to a 4x4. http://www.67-72chevytrucks.com/vboa...d.php?t=448681 I see no need to narrow any differentials. I may have a set of rear cargo doors (barn doors) but I'm a few hundred miles north of you. |
Re: New Member
Yes I am in Poky.... I'll email you about the doors...
Thanks, Bob |
