-   -   Trans cooler lines (https://67-72chevytrucks.com/vboard/showthread.php?t=806548)
Rick Bollinger 05-19-2020 09:52 PM
Trans cooler lines
Has anyone used this type of fittings for their transmission? Also with the stainless tubing and compression fittings.
Thanks for your feedback
Sheepdip 05-19-2020 11:02 PM
Re: Trans cooler lines
They will work as long as the final connections at both ends are hose/flex...mighty expensive though.
KQQL IT 05-20-2020 12:36 AM
I did these. Very pleased with them
https://www.advanceadapters.com/prod...-516-fittings/
71CHEVYSHORTBED402 05-20-2020 10:24 AM
Very cool & can't miss.
67/Heaven 05-20-2020 12:00 PM
Those appear to be Swagelok fittings, rated to 10,000 psi, I used them on my brake lines, never any issues. They have a two piece ferrule make sure the small ferrule is oriented correctly. Best fitting on the market IMO
Rick Bollinger 05-20-2020 11:22 PM
Thanks everyone for your input I think I will use them.
