-   -   New squeaky cab mounts (https://67-72chevytrucks.com/vboard/showthread.php?t=809807)
Submariner616 07-28-2020 10:53 PM
I just installed new rubber cab mounts on my '65 and now she squeaks going down the road! Ugh! Anyone know how to stop them from squeaking? Something that won't degrade the rubber?
SkinnyG 07-29-2020 12:21 AM
Re: New squeaky cab mounts
They should not squeak, as they should not be moving.
Are the bolts done up tightly?
Is something -else- squeaking, now that things are more rigid?
Submariner616 07-29-2020 02:14 AM
Good point. I'll double check.
AcampoDave 07-29-2020 07:12 PM
My new rubber cab mounts squeak too! I made sure they are tight and still the squeak goes on. Cheap ass China rubber probably.
I even went back and used the grade 8 bolts and tubes from my poly mounts to try to stop it and still no luck. The kicker is the poly ones never squeaked. They just transmitted a lot of harshness and vibration. I may put them back in though because the squeaking drives me nuts.
Submariner616 07-29-2020 08:16 PM
After I moved my gas tank to the back, under the bed, I removed the lower gas tank mounts before installing the cab mounts. I used large fender washers on the inside. I thought that might have caused some squeaking, but no. I was considering using a silicon lubricant on the rubber cushions and reassembling.
AcampoDave 07-30-2020 12:16 AM
Ditto everything you said. It's like you're posting about my truck. Except I only removed one gas tank mount and that's the one that squeaks. Washers were no help. On the other side, I cut only the tank flange and left the captive square nut and no squeaks. I have some leftover poly bushing grease and I will use it if it doesn't magically stop on it's own
Submariner616 08-05-2020 08:58 PM
I torqued the bolts to 80 ft lbs and it greatly reduced the squeaking a lot.
AcampoDave 08-05-2020 11:39 PM
Is that what they're supposed to be?
Submariner616 08-06-2020 12:12 AM
The spec in the manual says 70 - 90 ft-lbs
AcampoDave 08-06-2020 12:21 AM
Wow, I would've never guessed that they had to be so tight. Thanks for that I'll get out the ol' torque wrench and crank them down this weekend.
