-   -   Loose Shock Mount (https://67-72chevytrucks.com/vboard/showthread.php?t=811416)
Minkota 09-02-2020 08:01 AM
Loose Shock Mount
My upper front shock mounting stud came loose. the stud is still in the shock so i need to stop on the way home a buy the nut and lock washer. does anyone know what size it is? it looks like it might be 1/2" but I am not sure, hard to tell in the dark on the ground.
kwmech 09-02-2020 11:45 AM
Re: Loose Shock Mount
Loose in the frame?? 5/8'' fine thread, plus lock washer. That is the most common
Minkota 09-03-2020 07:17 AM
yes, came loose from the frame. Thanks
