-   -   12v Aux Battery connections (https://67-72chevytrucks.com/vboard/showthread.php?t=811812)
roll_the_dice 09-11-2020 05:35 PM
I am tidying up my truck in the engine bay and have so far 5 items that need a direct connection to the battery. I have the following connected to my battery or needs to be.
1. Starter (obviously a must)
2. Alternator (not a must, but I like how it is run to the battery)
3. FiTech Red Power wire
4. Electric Fan Relay
5. Headlight Relay
Is there anyway to not have all of these on the battery post? What have you guys done to hide your battery connected items?
I was thinking of something like this Distribution Block. I have also thought about a fused block. Or am I overthinking it?
nsb29 09-11-2020 06:13 PM
Re: 12v Aux Battery connections
This is mine a mega fuss under my relays where the voltage regulator was those wires on the left are for the fan not run yet Attachment 2047415
roll_the_dice 09-12-2020 09:22 AM
Thanks NSB...do you have one wire going to the battery and the rest are connected to this fuse buss?
nsb29 09-12-2020 09:34 AM
The two large cables on the bottom one goes to the battery the other one goes to the alternator from the upper terminal on the left one is the lead going to the fuse panel under the dash The other wires go to their relays above it for the lights and the fans
roll_the_dice 09-12-2020 04:46 PM
Where did you buy yours? I assume you bought some extra fuses to have on hand just in case?
nsb29 09-12-2020 06:02 PM
American auto wire it came in there kit and no I didn’t buy extra but should once it’s on the road
roll_the_dice 09-13-2020 10:44 AM
Thanks, I will check it out and see what I can find.
