-   -   Saginaw p/s steering gear identification. (https://67-72chevytrucks.com/vboard/showthread.php?t=812060)
Iplay4keepz 09-16-2020 11:59 PM
Hello all.
I've been having some trouble identifying the power steering gear box that's on my 1963 c20, originally 292 i6. The pump itself has the signature "S" indicating that it is a saginaw box, and there is a tag on the bottom that I believe reads "73-68."
Every thread referenced in the FAQ's shows a similar looking pump, but the pitman arm is flipped on the pump that was put in my truck at some point.
Power steering gear box commonly found in Faq section:
https://i.imgur.com/Rl4Hawo.jpg
https://i.imgur.com/IMJTSem.jpg
https://i.imgur.com/mxBUgBM.jpg
Power steering gear on my truck:
https://i.imgur.com/r8kcRzR.jpg?1
https://i.imgur.com/NOf9auk.jpg?1
https://i.imgur.com/aIBjVr6.jpg?1
https://i.imgur.com/AqkXL8C.jpg?1
https://i.imgur.com/IVp4pDY.jpg?1
https://i.imgur.com/UHPc9xw.jpg?2
https://i.imgur.com/Kr6lbxw.jpg?1
Google and searching has led me in circles so far so if anyone could shed some light that would be greatly appreciated.
The Rocknrod 09-17-2020 07:56 AM
Re: Saginaw p/s steering gear identification.
Wow. I have to noodle that around a bit. Never seen anyone have a pitman arm located like that.
Iplay4keepz 09-17-2020 01:40 PM
I havent been able to find anything about the pump itself. The whole steering geometry is different than what i usually see (I'll post more pics later on.) The strangest thing is that the tag number brings up a completely different pump!
The Rocknrod 09-17-2020 01:59 PM
I've n ever seen a box with Dual Arms out the bottom like that, is that what I'm seeing there?
Iplay4keepz 09-17-2020 09:30 PM
It's actually an idler setup hidden behind the box. It looks like when this modification was setup they did dual idlers (one, passenger side, one on the drivers side where i'm imagining the original box/pitman connect.) Then there is a connect point welded to the middle of the trailing arm.
I'm working on pictures but imgur isn't agreeing with me at the moment.
Iplay4keepz 09-17-2020 09:36 PM
https://i.imgur.com/UXGurts.jpg?3
Here is the drivers side idler tucked in behind the steering box.
Captainfab 09-17-2020 10:10 PM
That is the steering BOX not a PUMP. The pump mounts to the engine.
IMO that all needs to be torn off of there and the correct power steering box mounted properly with the correct steering box adapter plate.
Iplay4keepz 09-17-2020 10:19 PM
I can see where I have mixed up some of the wording in the original post. My question is still in regards to identifying the Saginaw steering box on the truck, not if I should replace it (I think that's a given at this point lol)! It's a situation of what the heck was put on this truck in the first place in case anyone runs into the same situation. It might not happen often but maybe 1 in a 1m.
The Rocknrod 09-18-2020 07:30 AM
I'd really put on normal c10/20 steering equipment, keep you're gear box, use this adapter plate and be done with it: http://www.67-72chevytrucks.com/vboa...d.php?t=332923
Iplay4keepz 09-18-2020 10:08 AM
Why would I reuse the gear box? I can't even figure out what its from.
The question remains. Does anyone know or have information on THIS gearbox.
The Rocknrod 09-18-2020 11:04 AM
That's easy enough to fix - https://www.summitracing.com/parts/a...del/c10-pickup
I personally have no info on your box.
Iplay4keepz 09-18-2020 02:31 PM
Great advice. I guess its easier to push people to site vendors than to answer questions honestly and straight forward.
The Rocknrod 09-18-2020 02:55 PM
a. they are not a site vendor.
b. it's a strange box.
c. even you said you cannot figure it out.
d. the suggestion was to buy a correct box, use the correct mounting plate and that is sound advice.
The answers you get may not be what you want to hear and I have no response to that.
We here on this forum are here to help "if we can".
Iplay4keepz 09-18-2020 04:58 PM
Throw it away and buy something else doesn't answer the question. It's not even helpful when the question is "what is this?" Not "how can I fix this?" That's all I'm saying.
raylube 09-18-2020 05:04 PM
See if this helps. https://leepowersteering.com/pages/h...entify-gearbox
Iplay4keepz 09-18-2020 05:37 PM
Originally Posted by raylube (Post 8810149)
Ive actually stumbled upon that site before. It seems to cover the styling found in almost every other chevy truck ive seen. Strangest part is that the most similar looking box goes on a ford. Even then it only shares the configuration of the pump, its very differrent otherwise. I think i will send them an email and maybe I can get a lead to chase.
raylube 09-18-2020 06:30 PM
There should be some more casting numbers. You may have to remove it and wire wheel it.
Iplay4keepz 09-18-2020 07:03 PM
Thank you raylube. Judging by the notes section I think this may be a really good lead as to identifying this part. It mentions ford units having a tag, which is present on the bottom of this gear box. All I have to do is get home and clean up the box. I'll see if there's any more numbers on it somewhere and post back.
