-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   wheel size specs. 91 with drop spindles (https://67-72chevytrucks.com/vboard/showthread.php?t=812624)
Marty68 09-30-2020 08:09 AM
2 Attachment(s)
i have an OLD... stalled project. it is a 91 GMC. i put rocker panels and cab corners in it they are finished new fenders ready to install. box patched and painted. drop spindles in the fronr. rear shackles and hangers in the rear.
the stock wheels seem to hit the a frames.
will 80s 15x7 or 8 ralleys solve this?
what inexpensi\ive alternatives are there?
thanks
Palf70Step 09-30-2020 12:34 PM
Re: wheel size specs. 91 with drop spindles
The 15x7s might clear. Depending on the drop spindle, the 15x8 may or may not clear. I know it is hit and miss on the pre 88 style trucks and I have heard it is that way on the newer ones also. The older ralleys have less back spacing, so they may clear your a-arms with out mods. Easiest way if you are already looking for new rims is to go 17". Other wise take a grinder and trim/grind the a-arm lip down so it clears the wheels.
Marty68 09-30-2020 07:21 PM
thats what i was afraid of
Stormin08 10-01-2020 08:15 AM
a arm or knuckle ?
i know of numerous OBS trucks lowered running a 15x7 with no issues.
it will be more dependent on back spacing than anything. Second will be diameter.
the 8" wheel may have the depth to contact the a arm on turns, but what i see more is contact with the tierod mount...
i remember way back, a friend used a lower budget name spindle, bolted on with out issue. i used a belltech, and my toe was way off, as they pulled the tierod mount way in to clear wider wheels.
Marty68 10-08-2020 06:19 AM
Originally Posted by Stormin08 (Post 8816312)
a arm or knuckle ?
this project is moving slower than the speed of govt. time will tell.
SCOTI 10-08-2020 07:01 PM
The 'van' ralleys clear drop spindles since it wasn't mentioned.
Van ralleys (15x6.5") front, 8" truck ralleys (15x8 in the rear:
Stormin08 10-12-2020 07:12 AM
good deal, i wouldnt really expect the narrow wheels to have the issues, but rather the wider in a smaller diameter.
SCOTI 10-12-2020 08:43 AM
Correct based on my experiences. Although when I put 18x8"s w/5.25"BS on my 74 C10, I had to trim back the 'rain gutter' for clearance yet the Van Ralleys that were on there didn't require it.
So, even larger diameter wheels might have interference issues depending on back-space/offset.
Stormin08 10-13-2020 07:36 AM
i think the overall relation of Dia to BS is the key as the arm flares to the mounting...basically, it hits further up the arm.
