-   -   Reproduction High Hump (https://67-72chevytrucks.com/vboard/showthread.php?t=813371)
Mikecc6 10-18-2020 01:07 PM
I need a high hump cover and firewall piece for 64 c10. The new reproduction pieces show they fit 1960-1962.
Will they fit 1964? They look like they will but I don’t want to buy something that won’t fit.
AcampoDave 10-19-2020 08:04 PM
Re: Reproduction High Hump
Don't know which one you are looking at but Slosh Tubz says they fit 60-66
https://www.sloshtubz.net/store/1960...nels-p78791513
Mikecc6 10-19-2020 08:09 PM
I did look at the Slosh Tubz piece and it does show 60-66.
I was really looking at steel pieces - Key Parts - and they show 60-62. I thought they were the same but don’t want to spend $300 and find out they don’t fit.
AcampoDave 10-19-2020 08:31 PM
Maybe you can give them a call. I'm not aware of any changes on the high hump thru the years except the way the gas pedal mounts. 60-62 used bolts and 63-66 had ball studs threaded in the holes but I still dont think that made the threaded mounting bosses any different.
nsb29 10-20-2020 06:53 AM
I used an original 60 in my 65
bigmoe 10-20-2020 04:39 PM
I have a high hump someone gave me but are they two piece? because it doesn't go all the way forward.
Mikecc6 10-20-2020 05:32 PM
There are two pieces. Firewall piece and cover
The Rocknrod 10-30-2020 03:04 PM
It's weird I havnt seen these for 64-66, I wonder why?
http://autobodyspecialt.com/chevy-pi...for-high-hump/
http://autobodyspecialt.com/1960-196...ll-4wd-models/
Ennehazrad 10-30-2020 04:47 PM
Have you checked LMC? Their high hump firewall piece says it fits 60-66 and costs $90. It’s at the bottom of the page- check it out...
https://www.lmctruck.com/1960-66-che...-filler-panels
https://www.lmctruck.com/1960-66-che...over-high-hump
PGSigns 10-31-2020 08:46 PM
The one key parts sells should fit the 63 to 66. I sold them both pieces a couple of years ago that I had here for my 65. The plan was to clean them up and laser scan the parts to develop the new parts. The difference I think is the 60 to 62 the hump was bolt in and the later ones were spot welded. I would not hesitate to buy the key parts pieces.
Jimmy
Mikecc6 11-01-2020 11:10 AM
Jimmy
Thank you. That’s the information I was looking for. Mike
