-   -   Bed pads? (https://67-72chevytrucks.com/vboard/showthread.php?t=815260)
71CHEVYSHORTBED402 12-04-2020 03:13 PM
Bed pads?
Working on a steel bed floor, bought the common available bed pads when I got into this thing, but then realized that messes up the body lines. I think those pads are 1/4", I don't care;)
I think some padding will improve the ride a pinch. The bed leaves a mark on the frame inviting rust too, not that rust is a problem here, but why mark up a refreshed frame if you don't have to.
I'm edging toward this 1/32" neoprene. No adhesive, maybe you know of an adhesive just strong enough to put the bed on? Grease is out:lol: I suppose I could get away with 1/16", there is a stretch factor. SWB bed probably weighs 400ish, but declared Tensile Strength on this 1/32" is 1000 PSI.
What have you used with success?
https://www.amazon.com/Rubber-Buna-N.../dp/B01LZI39LG
DeadheadNM 12-04-2020 04:47 PM
Re: Bed pads?
I used those little asphalt pads. Do my body lines look much off? Seem close enough.
71CHEVYSHORTBED402 12-04-2020 05:10 PM
Re: Bed pads?
I don't know more than that's a beautiful truck:chevy:
DeadheadNM 12-05-2020 09:55 AM
Re: Bed pads?
Thanks Tony!
