-   -   Stepside Spare tire hanger (https://67-72chevytrucks.com/vboard/showthread.php?t=819279)
roll_the_dice 03-08-2021 07:32 PM
I am working on my spare tire hanger. I have an OEM hanger with the 6 lug pattern. These are the 2 options I see to make it work for a 5x5 lug pattern...
Cut all 3 studs off and weld a 7-8" circular disc to the front with 3 new studs in the correct pattern
OR
Leave the face OEM cut the 2 bottom lugs off and weld 2 new studs in the correct place on the OEM face..See pic.
Which do you think would be a better solution? I am also open to other suggestions. Thanks!
AcampoDave 03-08-2021 09:11 PM
Re: Stepside Spare tire hanger
I lean toward option 2. It keeps it simple, more original, and less chance for rust by avoiding a pocket between 2 separate pieces of metal.
The Rocknrod 03-08-2021 10:37 PM
Originally Posted by acampodave (Post 8891329)
i lean toward option 2. It keeps it simple, more original, and less chance for rust by avoiding a pocket between 2 separate pieces of metal.
+1
SkinnyG 03-08-2021 10:54 PM
I will be cutting/relocating studs on mine, but using the existing plate.
Getter-Done 03-08-2021 10:58 PM
What about a thin wheel spacer adapter?
Use cap screws like this vvv
link: https://www.fastenal.com/products/details/2124365
And lugs pressed in?
example only:Attachment 2087681
roll_the_dice 03-08-2021 11:32 PM
Originally Posted by The Rocknrod (Post 8891387)
+1
I thought about the possibility of rust about the same time you posted. I do like the idea of it looking OEM...the only time it wouldn't look OEM though is if the wheel is off...but I would know. :) Thanks!
roll_the_dice 03-08-2021 11:33 PM
Are you going to use threaded rod or drill into the face and weld bolts from the back side?
roll_the_dice 03-08-2021 11:34 PM
Interesting idea...I did find this but pricey...
https://www.ballisticfabrication.com...mounting-plate
https://cdn.shopify.com/s/files/1/12...g?v=1594239549
Getter-Done 03-09-2021 12:11 AM
Yes that is the Idea.
Do you have a Drill press or hand drill?
You can make this yourself:metal:
SkinnyG 03-09-2021 01:25 AM
I'd likely weld bolts from the back side.
I also need to alter the mount slightly, to fit the long step brace to my short step bed, but that's not your issue here.
roll_the_dice 03-09-2021 10:09 AM
I have both, but I think I am going to cut off the 2 bottom studs and weld 2 new studs or bolts on. I think it will be cleaner in the long run, plus cheaper. :) Good suggestions though! We were thinking across the same lines!
Fortunately, I don't have to alter mine! Since I am a beginner at welding (literally) I think a bolt through the back and welded on will be simpler and easier. Thanks!
Thanks for the suggestions everyone and helping me think this through! I'll try to take pictures of the finished product when I am done and post here or at the very least on my build thread.
