-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   88-up speedo (https://67-72chevytrucks.com/vboard/showthread.php?t=819655)
legendman 03-17-2021 09:36 PM
88-up speedo
Are they all electric speedos, working on a swap in my 93 and would need a cable driven speedo.
Does the engine computer control the speedo ?
b454rat 03-18-2021 05:07 AM
Re: 88-up speedo
After 88 they are electric speed-o-meter. I’m pretty sure it goes thru the ECM. I had an 89 that I SAS’s with no speedo, CEL for no VSS or speed signal something or other.
legendman 03-18-2021 09:23 AM
Re: 88-up speedo
Thanks b454rat, this changes my plans.
MalibuSSwagon 03-18-2021 09:30 AM
Re: 88-up speedo
93 should have a VSS buffer box thats separate from the ECM, it receives the signal first from the sensor on the transmission and then sends the conditioned signal to the speedometer, ecu, etc.
https://harristuning.com/Tbi/vssb-drac-calibration/
http://www.tradecraftspecialties.com/DRACmodule
legendman 03-18-2021 11:27 AM
Re: 88-up speedo
Great info, Thanks
I think I should stick with leaving it TBI and the 4L60e, I just want something to cruise around with.
ChevyTech 03-19-2021 05:12 PM
Re: 88-up speedo
Yes!
Good accurate information.
The VSS buffer is also known as the DRAC
Just call me Sean 03-19-2021 07:00 PM
Re: 88-up speedo
VSSB and DRAC are two different things, as shown in the link. Modified DRAC on the left, unmodified VSSB on the right.
83GMCK2500 03-23-2021 10:39 AM
Re: 88-up speedo
The cluster plug changes in '92, so for your '93 the range you'll be looking for is '92-'94, unless you want to cut into the dash and repin the connector to the earlier style.
