-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   134a Conversion Question (https://67-72chevytrucks.com/vboard/showthread.php?t=823640)
tvhj 07-11-2021 01:39 PM
My '92 A/C has bit the dust and since I'm about out of r12 I'm converting to 134a. Plans are to replace everything in the system, new R4 comp., all hoses, etc. with the exception of the evaporator as I'm afraid the dash will crumble into pieces. Most parts are coming from RockAuto. After searching all the related posts here, I have not found a good part number for a drop in parallel flow condenser. Does anyone have a good brand and part number that they have used? Also not really sure which orifice tube and pressure switch to use. Thanks for any help, really want to get it right the first time.
legendman 07-21-2021 07:05 AM
Re: 134a Conversion Question
Are your R12 components still good ?
I am going to try this Redtek stuff on my 93 when the time comes.
https://redtek.ca/refrigerants/12a/
tvhj 07-21-2021 01:36 PM
Well the compressor is tired and leaking so I know I need to replace it. As far as I can tell everything else is good, just old as in original, so I thought I would replace hoses, condenser, dryer, orifice tube, and all "O" rings, especially if I went the 134a route. I would do the evaporator to, but he dash is so brittle, I'm afraid I would trash it. What is the Redtek stuff?
Just call me Sean 07-21-2021 01:43 PM
My dash was already trashed, but I did fiberglass cloth and resin to put it together/hold it together while I changed the evaporator.
