72 C-20 Help
Evening Guys I have a 72,C20 350 engine on the passenger side the original exhaust manifold im missing the front 2 bolts can i get the size i need to replace them and are they fine thread,s or cource threads?? Thanks Saddletramp
Re: 72 C-20 Help
I'm pretty sure that a 3/8'' coarse thread 1-3/4'' or 2-1/4'' long--sometimes a 1/4'' longer will work without bottoming in the hole. Check for this. Any brackets attached to this part of the manifold will require longer bolts
Re: 72 C-20 Help
Thank You for the answer appreciate it Saddletramp
Re: 72 C-20 Help
If you need two bolts and no stud end bolts I'll look tomorrow.
Re: 72 C-20 Help
Thank you that would be great Saddletramp
