-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   55.2-59 Static spring drop on my 55? (https://67-72chevytrucks.com/vboard/showthread.php?t=824108)
70ssclone 07-24-2021 10:35 AM
Hey guys, I recently snagged this ol 55 . It's pretty original as far as drivetrain it has a 235 with a 3spd and the original style suspension. Im not sure if any leaves have been taken put but I'm assuming it's stock height? I want to drop the truck but only enough that I'm not dealing with modifying much as far as a bed notch or bad steering geometry. Was hoping other members could list their setups on a Beam style axle and maybe point me in the right direction as what to buy .
mr48chev 07-24-2021 02:38 PM
Re: Static spring drop on my 55?
The truck looks stock height when it is upright.
You can scroll down the page to the 3100 diagram and find measurements that show how high the bed floor is off the ground (about 28 inches + /- )
https://www.gmheritagecenter.com/doc...2nd-Series.pdf
Right now one of the other guys is laughing and telling himself that "I knew 48 would show that photo again" This is what happens after a while when you remove several leaves from your springs in an attempt to get the truck low enough. This is on my truck so I am not badmouthing anyone else and my quick and nasty lowering job so I could drive the truck to two events late in 1989 before a planned chassis redo ended up being daily driven for 15 or more years before the 250 got so worn out it wouldn't run.
https://hosting.photobucket.com/albu...720&fit=bounds
I'm not saying don't do it but this is what happens when you do do it, The springs give out eventually plus personal experience of driving my truck over 100 K that way says that it really messes with steering and handling.
The photo of your truck was supposed to be at the top after I straightened it.
nvrdone 07-24-2021 06:38 PM
I wouldnt remove leaves or heat the springs to lower the front end. As 48 shows that messes with clearance between the chassis and bump stops. Plus your steering goes all wonky. I did it and regretted it immediatly. I then used a 3" dropped axle from Nostalga Sid -droppedaxles.com. 3" seems to be the lowest with out messing with your scrub line. check out Sid's web site. Lots of good info.
70ssclone 07-24-2021 07:25 PM
2 Attachment(s)
Thanks guys, so I can tell you that the front has 2 leaves and the back has 8 . I'm not sure what's stock. I'm guessing the PO pulled leaves from the front but left the rears stock.. sorry about the crooked pics I don't know why it does that ..
mr48chev 07-24-2021 08:06 PM
3 Attachment(s)
I'm thinking that you don't have any room to go on the front as far as altering the springs any more than they are. You can see that the bumpers on top of the axle have already been cut off short like mine are. You can also see that the bumper has been banging on the frame a lot.
On the rear it looks like there have been a few leaves removed already.
If you open the link to the pfd that I posted in post 2 an scroll down the page to the springs you will see that the front springs should have 6 leaves and the rears should have either 6 or 8 in the main spring pack. 2 stage had 6 leaves in the main pack plus the overload pack.
I think there is a kit to raise the shackles on the frame in the rear to lower the rear an not flip the axle and use a C notch.
On the front I don't know where those two thick leaves came from but bet that the ride quality isn't that great along with it not being as low as you want.
mr48chev 07-24-2021 08:13 PM
Posies did make a two leaf 3 inch drop spring for TF trucks and if the ends of the second leaf taper that may be what you have.
70ssclone 07-24-2021 08:53 PM
Thanks ! The leaf does taper so I'm guessing he just did posies in the front and took some out of the rear. So I wonder if I did a 2" drop axle up front and the Shackle kit out back if that would get me what I want . Doesn't need to be crazy low just don't care for how Tall it is currently but I do like the rake it has I think a little rake on these trucks with that swept cab looks killer.
