-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   1993 washer nozzles (https://67-72chevytrucks.com/vboard/showthread.php?t=825478)
Kudzupatch 09-03-2021 09:12 AM
1993 washer nozzles
My washers nozzles seem to have an issue. The water just sort of dribbles out and sprays very low on the windshield. Not up high enough to clean the windshield.
I have checked everything. Replaced the pump. Check the lines from the reservoir all the way to nozzles. I assume there is something wrong with the nozzles but it is not obvious and just wondering if anyone else has seen this? Is it a design issue?
Doorman replacements are cheap enough but just wanted to ask before I go to the trouble of replacing them.
Second Series 09-09-2021 04:54 PM
Re: 1993 washer nozzles
I had a similar issue on my tracker. I disconnected the line from the pump and got good flow. I found some clogged check valves that I was able to clean out to restore function. Can you disconnect the lines to the nozzles and check if it sprays good there? You might be able to clean out the nozzles.
