-   The 1973-1987 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=5)
-   -   OR WTB 3-wire plug for tach (https://67-72chevytrucks.com/vboard/showthread.php?t=828019)
K25alive 11-22-2021 03:07 PM
Would anyone know if these plugs are available? This is the 3-wire connector that plugs into the back of the tach. In my case a OEM 1976 HEI tach. It would be great if they came with a pigtail.
66gmcguy 11-22-2021 03:35 PM
Re: WTB 3-wire plug for tach
LMC has a complete harness for $37. Are you missing the plug, or do you just not have enough wire length there to splice a new wire on? Napa auto parts carries those terminals and as long as you have the right crimping tool you can install a whole new wire. They are Delphi 56 terminals (or Packard 56 terminals or something)
K25alive 11-22-2021 04:01 PM
I'm going to need a new plug. I tried for almost 2 hours to get that plug off that tach but it will not budge. it is supposed to slide/pull right off the tach. Do not know what the problem is, but will likely destroy it to get it off.
RodnRudy 11-24-2021 02:38 PM
https://kwikwire.com/
These folks have everything you need.
