Anyone have their windshield out? Need to verify a dimension
Getting ready to weld in the windshield area.
I need to verify the width of the opening all the way across the very top of the WS frame at the corners. I want to make sure it matches the jig that I made for the spacing I had to remove it to put in the inner A pillars Attachment 2158437 |
Re: Anyone have their windshield out? Need to verify a dimension
Straight across inside corner to inside corner is 56 1/2" . :chevy:
I have another 67 cab burried in the corner of the garage , and 2 more outside covered in tarps , I'll move some stuff out of the way and get some more measurements . :chevy:
Sounds like Grumpy has you covered. I'm having the windshield on my Burban pulled and resealed here in another 30 minutes. Would have been perfect timing.
I'm going to confirm Grumpy's 56 1/2 measurement. That is what mine is.
this forum is better than four years of college
thanks to all….. I’ll post the results soon much appreciated |
I'll post my dimensions shortly. Gotta have dinner with the wife first 😉
Same. 56 1/2".
Just to check with you guys but is that the straight line dimension or is that following the windshield curve?
I’ll make a new gauge to go across and clamp everything in place I don’t want any surprises when I go to install the windshield |
Just to be Crystal clear, I assume you are measuring from the end of the black arrow and not the end of the red arrow?
https://67-72chevytrucks.com/vboard/...ictureid=26695 Thanks! |
One last question. What is the distance between the drivers and passengers sides where the red arrow is?
https://67-72chevytrucks.com/vboard/...ictureid=26697 |
I get 57 1/4
Kind of hard to measure with one person. Tape measure basically rests on the top of the dash to measure. |
Awesome!! Thank you so much!!
How about top to bottom in the center of the frame opening?
Thanks |
Come on guys I really need this measurement,,,,,,, please.....
I made braces for that area because I'm replacing the windshield header on this cab.
It's not the best picture, but I did go out to the shed to verify...21" Attachment 2363615 |
| All times are GMT -4. The time now is 07:47 AM. |
