-   -   Cab visor (https://67-72chevytrucks.com/vboard/showthread.php?t=831013)
Lethal Tendencies 02-14-2022 03:33 PM
Cab visor
Anyone make a cab windshield visor?
sick472 02-14-2022 05:22 PM
Re: Cab visor
This is the only one I know of...
classictruckconsoles.com/classic67-72chevytruck_sun_visor_gmc60classicfiberglass.htm
I have not dealt with them. I just ran across them searching for the same thing you are...a new cab visor. I finally gave up on the idea. I like the old Lund versions and was not going to pay for a 40+ year old, as-is, used piece of fiberglass for a few hundred dollars.
Lethal Tendencies 02-15-2022 08:53 AM
Re: Cab visor
The one in your link isn't too bad. I was looking for something a little more low profile and possibly made out of aluminum. If I had a sheet metal brake I would make my own.
BigBird05 02-15-2022 09:38 AM
Re: Cab visor
Did you watch the TV show Full Custom Garage where he made one with no brake. Just garage tools.
Lethal Tendencies 02-15-2022 10:42 AM
Re: Cab visor
I will have to look for that. Thanks
pwdcougar 02-15-2022 04:43 PM
Re: Cab visor
2 Attachment(s)
Lund used to make one, not sure if they still do. This one came off a 70 suburban. Sorry though it's long gone.
LS short box 02-15-2022 06:05 PM
Re: Cab visor
Body shop guys loved those visors. Not too long after install with sheet metal screws the wind flexes the visor and loosen up the sheet metal screws making the holes bigger. Soon you got 3/8" holes in you roof.
Now the body guys get to make some money off fixing the holes.
LOL!
Lethal Tendencies 02-16-2022 02:40 PM
Re: Cab visor
The lund visor is ok. But I was looking for something that would attach to the drain ridge. I think something like this design would be cool
special-K 02-17-2022 07:21 AM
Re: Cab visor
2 Attachment(s)
Unfortunately, J&J Enterprises either no longer exists or the don't make visors any more. The used to make one in steel that was actually designed to go with the 67-72 body style. The Lund visors are generic one size fits all style. Yes, made for individual fit, but not individual style. They look like they were designed for Fords, or look best on them. Especially the 9000LTL
Attachment 2168534
90% of big rigs run visors and they don't work lose or cause body damage body guys love. I ran a J & J visor on a '70 work truck for years with no poor consequences. Those mount with nutserts, so you start off with a 7/16" hole (IIRC) that never gets bigger. I had an extra one I sold to a member in Oregon years ago. I wish I could find a picture. One like those could be made fairly easily. Looked a bit like the one showed with holes. These had a step-up in the center, about 6" wide, and louvers to relieve air pressure. No louvers would probably be ok as long as a space between can and visor allowed passage of air
I also had a fiberglass one on my '71 wrecker the previous owner had installed many years ago. Called the Supervisor, that went really well with the body design. It went down more than up. No body damage on that one, either. Those go back to the '70s van craze, mostly designed for vans
tim_mc 02-18-2022 11:39 PM
Re: Cab visor
I don't know, but that 'Supervisor' might have a 2nd life in aftermarket if done correctly. I think it looks good on your wrecker and has that '70s vibe.
Mudder 02-19-2022 01:36 AM
Re: Cab visor
2 Attachment(s)
I've had one on my truck for over 30 years with no problems.
special-K 02-19-2022 08:38 AM
Re: Cab visor
I never saw your truck white. That's cool to see.
I guess if someone didn't tighten the mounting screws, skimped on them, or they happened to work loose unnoticed long enough, I could see problems from that. We need to pay attention to our vehicles. I can't imagine not noticing a visor being loose that long to do rip out the holes.
I remember traveling a 12hr trip in a girlfriend's 4-Runner and hearing a tapping or other not so loud noise from up above. I pulled over to discover the factory wind deflector for the sunroof had a screw that backed out and others working loose. I removed it and fastened it back on once home where I had more screws. I caught it before it damaged paint or anything else. I've seen windshields get ruined due to a simple deteriorated wiper blade going untended to right before the drivers eyes, literally. How that goes unnoticed evades me
