-   -   Left rear turn signal/flasher no power (https://67-72chevytrucks.com/vboard/showthread.php?t=831126)
kcstreetracer 02-17-2022 02:56 PM
So I've been chasing down wiring issues trying to get the left rear turn signal/Hazzard to work. No power to the left rear turn coming from fuse block where it plugs into the rear harness..All wiring and fuse panel is new. Every other light works. Fuses are good. Any idea where I start with this?
sick472 02-17-2022 03:51 PM
Re: Left rear turn signal/flasher no power
Where/how are you testing for power at the left turn signal? More importantly, if your using a multi-meter...where are you placing the probe for the ground?
kcstreetracer 02-17-2022 03:57 PM
I'm just using a test light. Testing coming out of the fuse panel where it plugs in to the rear harness at the firewall.
BigBird05 02-17-2022 04:07 PM
Is it the original turn signal switch?
kcstreetracer 02-17-2022 04:09 PM
No. Its new. Left front, right front and right rear turn signal works. Just left rear doesn't. No power for the left rear wire coming from fuse panel.
pjmoreland 02-17-2022 07:48 PM
The yellow wire for the left rear turn signal light comes from the turn signal switch. That's why BigBird05 asked you about the switch. You could either have a faulty turn signal switch, or you've got a flaky electrical connection somewhere, possibly on the crescent-shaped connector for the turn signal switch. Maybe the yellow wire terminal wasn't crimped correctly on your new switch.
If you wiggle the turn signal lever around a little, can you get the rear turn signal to start flashing?
With your left front turn signal flashing, is there any power on the yellow wire at the turn signal switch connector?
kcstreetracer 02-17-2022 08:26 PM
So I went out and there is no power coming from the yellow wire coming off the column. It is a new column that came with the truck so the turn signal switch is new as well. So is it safe to say the switch is bad? I
pjmoreland 02-17-2022 08:42 PM
Power comes into the turn signal switch via the following wires:
Brown - hazard lights
Purple - turn signals
White - brake lights
If your hazards, turn signals and brake lights work at least on some of the bulbs, then it seems safe to say you have power going into the switch on these three wires. You just don't have power coming back out of the switch on the yellow wire. I interpret that as faulty switch contacts, a poorly crimped terminal on the yellow wire, or a severed/detached yellow wire inside the column.
pjmoreland 02-17-2022 08:51 PM
Do your brake lights work on both sides? If yes, then that would indicate the yellow wire is intact inside the column.
kcstreetracer 02-17-2022 09:07 PM
Right side brake light works. So I keep messing with the yellow wire and got it to flash my test light finally. But the test light probe will arc on the probe when I touch the yellow wire. Something funky is going on! The dash harness and all of the wiring is brand new american autowire factory style plug and play. So I guess now the we could say the switch is good? But there is still no power to the firewall where the rear harness plugs in. The steering column is a el cheapo chrome unit that came with the truck when I got it. It hasn't had any use really other than driving around the block once. I wouldn't think anything with it would already be bad. But I guess if it's made in China lol
pjmoreland 02-17-2022 09:14 PM
If you're getting power on the yellow wire out of the column, then that does indicate the switch is good. Sounds like you've got a flaky connection either at the switch connector or at the firewall connector. You might want to pop the terminals out of both halves of the switch connector so you can visually inspect them. Maybe one of the terminals is poorly crimped. Soldering the wire strands to the crimp terminal is a good way to fix a poor crimp.
kcstreetracer 02-17-2022 09:23 PM
10-4. I'll take a look at that this weekend. I Appreciate the help and insight to get me in the right direction. Wiring is not my strong suit lol
