Precision brand fuel tank from O'Reillys
I just picked up a Precision brand fuel tank from my local O'Reillys store. Only took two days for them to get it. Made in Canada not the Taiwan tank that you might receive from an online vendor & you don't have to pay shipping shipping and oversize fees to get it.
I'll update once I install the tank to let everyone know how it fits. |
Re: Precision brand fuel tank from O'Reillys
Thanks, Rg |
I am very interested to know your "happiness" with it also. I have kept every single part I have taken out of my truck with the exception of the gas tank. (In cab.) The tank is the only thing I have disposed of and I have been kicking myself for doing so after I read so many nightmare stories about the filler neck not fitting (and cracking after tweaking) in the repros. My tank was likely 100% good, it just had 15 years of gas goo in the bottom that probably could have been dealt with. Oh well, live and learn! Good luck with the install.
I have one of those Precision tanks in my truck right now. I'm 99.9 percent sure it is made by Spectre (Canadian brand) and rebranded Precision for O'Reilly's. I went through replacing my in-cab fuel tank last year and documented the ordeal in this thread https://67-72chevytrucks.com/vboard/...d.php?t=821499. There are lots of pics in that thread that show the incorrect neck alignment.
The final result was a tank that seems almost as sturdy as the original with a neck that works but is not perfectly aligned with the cab. The original tank was perfectly aligned. Issues I ran across with the Precision/Spectre tanks, out of four tanks, none of them had a properly aligned neck. I think this is probably due to how they package their tanks for shipment. Their boxes allow the neck to stick out unprotected. This allows it to be easily knocked around. A lot of guys say they have massaged the misaligned neck to straighten it out. We tried that and it ended up with a leak at the point where the neck connects to the tank. If I hadn't been in the middle of planning a move across the country I would have cleaned out my original and run it for a while to see how it held up. I still wish I had gone that route. I've added a couple pics for those that don't fell lik clicking the link to my other thread. https://67-72chevytrucks.com/vboard/...1&d=1620327702 https://67-72chevytrucks.com/vboard/...1&d=1620327777 |
The tank installation went great. Slipped right into the grommet , all the bolt holes lined up & I have no issues with the neck alignment.
Dang, that looks good. Wish mine would have gone that smoothly. Maybe I’ll try again. The Spectra/Precision tanks seem to be great quality replacement tanks. I just couldn’t get one out of four to have a properly angled neck. Maybe the fifth one would’ve been the charm. Lol. Congrats on a smooth install.
Question: Was the neck poking out of the box when you got yours? All four that I got had the neck sticking out. You could tell the flaps of the box were designed to be that way. It wasn’t a case of the tank shifting around during transit and causing the neck to burst out of the corner of the box. |
I put that tank in mine also.
My tank had a bent neck that I was able to re-align using a floorjack handle.
I also purchased a Counterparts (made in Taiwan or China) form our local 67-72 Chevy truck specialty shop and it was listed as fitting 67-72 trucks (should've known there'd be problems with that). The tank was flimsy, could push the wall of the tank in about half to three quarter of an inch and the neck was skinny (for a 71-72 truck). However, it was packaged great with styrofoam in the box to prevent movement and the neck was inside in the box. Also, the neck was at the correct angle. I posted a pic of the Spectra tank on my Instagram and Spectra responded that they would like to talk with me but when I called them the operator redirected to a voicemail box. I left a message but didn't hear back from them. Pretty frustrating. |
I have a nice original out of truck that was from AZ if interested? $85.00 plus shipping
After reading a few of these replacement tank threads, I am happy I decided to have my '72 tank taken to a radiator shop that cleaned it out and sealed it. I am pretty sure it cost about as much as a replacement to have that done (if you factor my brother's time, then more toting it back and forth). I am pretty sure I'll never have to worry about my tank (and man it was a mess inside too).
It seems very surprising that any manufacturer would ship a bit of their product outside of a box - especially something like a neck on a fuel tank. It's like someone asked themselves, how can we get these rejected and sent back to us? Makes me wonder if O'Riley's would get them bulk and then ship them individually to their stores from their warehouse? |
Thanks for the update 67 Twins. Based on your experience, I'm going to pick one up. If the neck looks like it will need too much tweakage, I'll just take it back. Nothing lost but some time and no need to deal with shipping hassles. P/N FT5197 (without evaporative emissions control) due to 1970 model. Is that what you installed? $219 and there is a 10% off coupon deal right now.
2 Attachment(s)
It seems that’s just how Spectra/Precision fuel tanks are packaged. My two Spectra tanks came from Autozone and the two Precision tanks came from O’reilley. The packaging was identical except for the Precision or Spectra sticker on the boxes. Clearly they do a better job packaging their radiator cores.
An aluminum rad core is probably more susceptible to damage that would cause a leak than a steel fuel tank.
take care.Greg |
| All times are GMT -4. The time now is 01:35 AM. |
