-   -   Preferred Booster off Captain Fab's List? (https://67-72chevytrucks.com/vboard/showthread.php?t=832024)
Bushman66 03-13-2022 11:17 PM
I have his bracket and the list that came with it, and was wondering if there was a "preferred" booster off the list that is a little bit better than others due to size of the booster, more vacuum, better fit, etc etc? Will be a standard front disc/rear drum conversion on a 66 C10.
I was leaning toward a Dual Diaphragm (read Captain Fab's recommendation in a different thread, that the dual diaphragm is almost always preferred). Not sure if the 88-98 full size pickup or 68-82 Corvette booster is dual diaphragm?
Thanks!
The Rocknrod 03-14-2022 08:12 AM
Re: Preferred Booster off Captain Fab's List?
Thanks!
Corvette Dual Diaphragm - https://www.corvettecentral.com/c3-6...-chrome-193107
And according to the GM heritage Center Download the 1988 C1500 Extended Cab had a dual Diaphragm.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
cerealwars 03-14-2022 08:29 AM
In my '62 V8 4-speed, I used a booster for a 1994 Astro Van (ACDelco PN 14PB4277) along with a 1.125 bore MC - ACDelco PN 18M1878.
This setup has good pedal feel and the Astro booster's smaller diameter fits well with clearance to both my air cleaner and the clutch MC.
Bushman66 03-14-2022 04:09 PM
Thanks fellas!
