Another steering column question
2 Attachment(s)
Hoping not to get bashed on a subject that has been talked about since the Stone Age, I am putting a column out of a 67-69 c10 in my 63gmc. Removing three on the tree and putting in straight floor shift column. I have been looking through the forums and found a ton of info but nothing about using the original steering wheel on the later column. What is required to use the original wheel and maintain turn signal functionality and horn. I assume these turn signals automatically turned off when the steering wheel is turned back to straight? Mine has been broken since I have had it so I do not know… one picture is my 63 column on the bench
Attachment 2230789 Attachment 2230790 |
Re: Another steering column question
I put a '64 wheel on a 67-72 column without any modification or adapters. The main differences were under the hood in that swap
| All times are GMT -4. The time now is 07:41 AM. |
