-   -   Who has an electric fan? (https://67-72chevytrucks.com/vboard/showthread.php?t=84171)
72superBB 01-06-2004 01:46 AM
Who has an electric fan on their radiator insted of the motor driven one?
Is is worth it & do you notice any difference?
Ron
jamesjones 01-06-2004 01:57 AM
I've got a single electric fan on my 72 Blazer. It was put in by the previous owner and is switch activated. As far as how well it works. :rolleyes: You got me. I don't drive it all that much right now to tell the difference. The previous owner used to take it out to the desert a lot and told me he didn't have any problems. Take that for what it's worth. One advantage though is getting rid of the parasitic mechanical fan. I think that's a couple horses right there. Not sure if I helped but there you go. :)
James
bigvinnie 01-06-2004 02:00 AM
yeah, I notice my motor not overheating in traffic, so I'd say it's definitely worth it... there's some vendors on the board selling kits for these trucks, or you can do a search and find lots of info on junkyard setups that people on the board have used...
1972C10 01-06-2004 02:04 AM
i put dual 14" fans on my 72 hopin to get the temp down didnt notice any change in the overall operatin temp never got hot sitting still after fan upgrade
Seemed to have more bottom end after the fan upgrade it would spin the tires easier Seems ive read that it frees up 15hp but thats acording to an ad tryin to sell electric fans lol.
72superBB 01-06-2004 02:06 AM
WHat kind or where did you get them from? Have any pics of what it looks like?
THanks
Ron
Low69CST 01-06-2004 02:30 AM
I have a dual flexalite fan set up with a painless wiring relay kit. It cools my modified 400 small block just fine. Its not too loud either. Don't have any pics right now though, sorry.
bigvinnie 01-06-2004 02:38 AM
looks like there's a problem with posting pics, keep getting a network database error...
I'll try to post pics of my setup later...
1972C10 01-06-2004 02:43 AM
I can post pics of mine tommorow its dark outside now
Earl Junior 01-06-2004 05:09 PM
I had trouble keeping my 500 cool, even after putting in a giant radiator (I'm using a 6.2L diesel radiator with dimpled tubing), until I switched to my electric fans.
The change was night and day.
I'm running two 16" Flex-a-lite fans because it was cheaper to buy two than to buy a dual setup. I think they were on sale through Jegs at the time. They came with relays, temp activated switches and all the wiring needed to install them. Right now, they kick on when the temp gauage hits about 3/8.
I don't really like having them attached using the push-through things, but I've not had time to fab up a shroud.
http://www.earljr.com/images/drivefan.JPG
http://www.earljr.com/images/dualfans.JPG
Classic Heartbeat 01-06-2004 07:32 PM
Earl Junior, You will be lucky if that set up doesn't ware a hole in your radiator. I had the 12" fans on mine and they did in less than about 3 months. $289.00 down the drain!! The radiator companies will not warrantee their radiators when you do that. That is why I designed shrouds for our trucks. They also give better air flow through the radiator. http://www.classicheartbeat.com/cata.../67-72%203.jpg
http://www.classicheartbeat.com/cata.../67-72%201.jpg
WES www.ClassicHeartbeat.com
Mudder 01-06-2004 09:08 PM
I have a single electric fan. I believe its rated as about the highest there is in pulling air. Preset thermostat. It does alright. Runs a little hotter when it's over 100 degrees out on the highway (200)....than I would like but most have told me the vortecs run a little hotter.
Low69CST 01-06-2004 11:50 PM
I found some pics of my electric fans, the board isn't allowing me to post them for some reason. If you want them, just email me.
Leinie 01-07-2004 12:17 AM
I put two electrics in my Blazer like Earl Junior. He's right about the push through buttons, they wore holes in the radiator tubing.
I had them set to run at different temps so if it was really running warm the second fan kicked in. It worked very well until the leak!
rn2fine 01-07-2004 04:33 AM
Electric Fan
I used a Flex-A-Lite Black Magic 15". It pulls 2800 cfm and has integrated shroud, integrated thermostat, and integrated ac relay. Put it behind a 28x19 Northern Aluminum radiator that is smaller than stock. I have a 72 c10 Suburban with a 350, live in Arizona, and have AC. Have not used in summer yet. Have 180 thermostat and have fan set to come on at 187. It rarely comes on (even when idling) and when it does it is only for a few seconds. Have metal radiator hoses. Touched them the other day while running and was surprised that lower hose felt at least 60 degrees cooler than upper while idling with fan not on. The aluminum radiator makes a huge difference. Fan set me back just under 200 bucks. Radiator was approx 275. Got the radiator from www.racingradiators.com. Don't have any pics to show but may post some in near future.
gonebad2 01-07-2004 05:09 AM
I got mine at Summit Racing. It's a Derale (Summit Part Number DER-16516) It's 16" "S" swept blades and pulls 2175 CFM. Truck is still being built so I can't comment on the performance yet. The true test will come this summer. We get a couple of warm days in the summer but not too bad. I also installed the Painless Wiring thermostat and relay kit. Truck has complete Painless harness. So needless to say, the installation, was, well, painless. I think I will remount it with an aluminum shroud though. I wasn't very impressed with the push-thru steel rods supplied with the fan. I am a little concerned with the fan rubbing against the aluminum radiator. To make a little more room, I frenched the radiator into the radiator support before I had the powdercoating done. I gained about 1-1/2" and would still be able to add a belt driven fan to work in unison with the electric fan just in case.
GMan69 01-07-2004 08:03 PM
I went with the Spal dual 11" fans. They are shrouded and include a wiring harness and thermostat. They pull some serious air. I'll send pics asap.
George
